What have you made/created today?
Discussion in 'Garage / Workshop' started by ERMB, Oct 28, 2014.
  1. Aug 16, 2019 at 11:40 AM
    #1361
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    have you ever had them resharpened? I dont know if its worth it or if even possible...I still have the blade I changed out, it was cutting ok, but the edges were starting to rip out so I know it was getting dull.
  2. Aug 16, 2019 at 1:54 PM
    #1362
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    From what I’ve read, based off the cost for sharpening carbide blades, these ones aren’t really worth it. They are basically decent quality disposable blades. You could do a diy sharpen but it’s almost 50-70% the cost of the blade to have a pro do it.
    As long as you haven’t burnt the blade, a good pitch remover can make a big difference though.
    wilcam47[QUOTED] likes this.
  3. Aug 16, 2019 at 5:46 PM
    #1363
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Been planning on making one of these for myself for a while now. I collected enough shells, I told my shooting buddy I would make him one when I do. Next week is his birthday and I decided to make his first. Mine is gonna be full sized with the ends of the shells for the stars. His is just a mini version, so I didn’t want to short the stars.
    gasparic104, nagorb, Fiend13 and 8 others like this.
  4. Aug 16, 2019 at 7:10 PM
    #1364
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Looks good. How did you attach the shotgun shells? Hot glue?
    wilcam47 likes this.
  5. Aug 16, 2019 at 8:11 PM
    #1365
    wilcam47
    Will
    Bourbon state
    kind of figured as much...A nice sharp blade is sure nice.
    shane100700[QUOTED] likes this.
  6. Aug 17, 2019 at 2:56 AM
    #1366
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I used E6000 adhesive. I had 3 tubes from my old job. On mine I might switch to hot glue. May not have enough E6000 to do it all. I have some industrial hot glue laying around. Guess I’ll see how his holds up. Or maybe I’ll go with epoxy or maybe lay it in fiberglass resin?
    wilcam47 and buyobuyo[QUOTED] like this.
  7. Aug 17, 2019 at 4:12 AM
    #1367
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    Yea those Diablo blades are cheap, but they are all thin kerf blades and the table saw I have is a 9" saw which isn't common these days so Home Depot/Menards etc doesn't sell them in 9". I had to order my Freud Combination blade from Amazon.
    I think the resin would be awesome AF, but I wouldn't make it my first resin project unless you had access to more shells in case it goes awry. Post pics if you get it done!
    shane100700 and wilcam47[QUOTED] like this.
  8. Aug 17, 2019 at 6:13 AM
    #1368
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I’m a member of a gun club, and shoot at a few others. The white shells are the hardest to find. We just got a new store in town that sells the Federal red white and blue shells so we may now start seeing them more often. I have a whole bag full but the full sized flag uses about 350 shells total. I’ve used resin a bunch of times back when I worked at a car audio shop. Shouldn’t be any problems if I mix it right. That might actually be the way to go as it will also flow inside the shell to better bond it all together. However the added weight may be an issue.
  9. Aug 17, 2019 at 6:20 AM
    #1369
    Kilo Charlie
    Iowa
    Are you making a full sized one to hang on the wall or a table? The table weight wouldn't be an issue but hanging it on the wall would require a little extra... but otherwise.. I think it's a brilliant idea and can't wait to see it.
    shane100700 and wilcam47 like this.
  10. Aug 17, 2019 at 6:45 AM
    #1370
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    What is "full size"? Flags come in lots of sizes. Also, if you do the resin/epoxy, have you thought of putting holes in the side of the shell that is down, so you have glue all the way through the wall of the shell instead of just on the inside?
  11. Aug 17, 2019 at 7:28 AM
    #1371
    wilcam47
    Will
    Bourbon state
    how many teeth? Are they good for ripping cuts?
  12. Aug 17, 2019 at 8:18 AM
    #1372
    Kilo Charlie
    Iowa
    40 Teeth.. and the Combination blade is made for both ripping and cross cuts. Super slick and super quiet!
  13. Aug 17, 2019 at 8:26 AM
    #1373
    wilcam47
    Will
    Bourbon state
    diablo must be the cheaper version...made by the same company. LOL How thick are the teeth? they look pretty stout.
  14. Aug 17, 2019 at 8:30 AM
    #1374
    nopinch
    nopinch Active Member
    Broken Arrow , Ok
    Interior trim edge for a 56 Chevy
  15. Aug 17, 2019 at 8:30 AM
    #1375
    Kilo Charlie
    Iowa
    1/8 inch - it's a full kerf blade. This is what I used ion that last batch of cutting boards made of Maple, Walnut, Cherry, Purpleheart and Padauk ... cut right through it all
  16. Aug 17, 2019 at 8:31 AM
    #1376
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    :drool:
  17. Aug 17, 2019 at 8:33 AM
    #1377
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    It’s kind of amazing the differences tooth count makes. Before getting into woodworking I always thought, the more teeth, the smoother the cut.
  18. Aug 17, 2019 at 8:45 AM
    #1378
    Kilo Charlie
    Iowa
    I did a little research before buying.. there are like 80 tooth blades out there.. but I don't see the point of them all. This blade has so far done everything I have needed it to do so I am ok with that, especially on a 45 year old saw!
  19. Aug 17, 2019 at 8:50 AM
    #1379
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I have about 7 blades, no dado so far. The 40 tooth are the ones that stay in the miter and table saw most times.
    Bigdaddy4760 and wilcam47 like this.
  20. Aug 17, 2019 at 8:59 AM
    #1380
    Kilo Charlie
    Iowa
    I haven't come across anything I've needed a dado blade for yet and between the 3 saws I just acquired, there must have been 50 blades with them. I haven't a use for any of the old ones due to the newer technology like in the Freud blade. I figured I would start my own collection of blades LOL
