What have you made/created today?
Discussion in 'Garage / Workshop' started by ERMB, Oct 28, 2014.
  1. May 8, 2020 at 7:20 PM
    #1781
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    You got room for a cuda in there...
  2. May 8, 2020 at 7:20 PM
    #1782
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    :rofl::rofl::rofl:
    StayinStock and wilcam47[QUOTED] like this.
  3. May 8, 2020 at 7:28 PM
    #1783
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    My buddy at powdercoat had us make this prototype out of wood a couple years ago as a test. He wanted to see if it worked then he was going to have us make two out of steel. They’ve added to it and fixed and repaired it. He brought it to me today at lunch and ask for 2 by Monday afternoon. Check. He said they’ve ran approximately 3 million parts through this one. They put 5 parts in it and wrap them. I need about an hour in the lathe and I’ll be done with them.
    Fargo Taco, wilcam47 and StayinStock like this.
  4. May 8, 2020 at 7:28 PM
    #1784
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Been working on it for awhile, turned out good!!
  5. May 8, 2020 at 7:32 PM
    #1785
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    He's nobody's friend:wink:
    Thank you sir! I actually had a great time doing it. Crank up the music and go!
  6. May 8, 2020 at 7:32 PM
    #1786
    wilcam47
    Will
    Bourbon state
    Whats it for?
  7. May 8, 2020 at 7:36 PM
    #1787
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    They paint landscape stakes then use this to wrap them in bundles of 5.
  8. May 10, 2020 at 4:18 PM
    #1788
    gasparic104
    gasparic104 Trusty Spotter
    Cayleigh
    Instagram: @NotSo_JDM
    2015 Tacoma TRD Sport DCLB; 21 & 03 Corolla
  9. May 11, 2020 at 11:30 AM
    #1789
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Not exactly Made or Created but....
    Several years ago I sort of inherited this old Coleman camp stove when a senior relative was being moved out of her house and into a nursing home. It has been sitting in my garage and gathering dust all this time and since I am running out of things to do because of this quarantine thing I decided to pull it out and see what I could do with it.
    The best I can tell, Coleman made this model, Model 425B, from 1949 to about 1961. A few leftovers were still on store shelves in 1962. Earlier models had a copper-colored tank and the later ones' tanks were painted red so I suspect this stove dates from the late 1950s.
    I should have taken a "before" picture but I didn't. It seems that a family of mud dauber wasps had taken up residence in it at one time so I had to clean all of that out. Then I removed the burner assembly, cleaned out the interior real good and put it all back together. The original paint is 99% intact with just trace amounts of rust.
    Then I removed the pump plunger and to my surprise the leather piston was still oily and is good condition. So I filled it up with some Coleman fuel (basically pure gasoline with no additives), pumped the tank, and lit it up. The burner fired after about 3 seconds and though you can't see it very well in the picture, it settled into a nice hot blue flame. I may go ahead and replace the tube that connects the fuel tank to the burners, (it's called a "generator" but I don't know why) because these tend to get corroded after a while.
    Never underestimate good old 'Murican technology!
    buyobuyo, nagorb, StayinStock and 5 others like this.
  10. May 11, 2020 at 1:56 PM
    #1790
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    Nice, Tim. My dad gave me the same one a few years ago, but I’ve never used it or even opened it up. I ended up buying a newer used one that uses those small propane tanks for taking my boys camping, but I’ve never even used that one! :D We’ve always had other ways to cook so I’ve never needed mine, but I may need to mimic your methods here.
    Tactical_Panda likes this.
  11. May 11, 2020 at 6:30 PM
    #1791
    Tactical_Panda
    Tim
    Fredericksburg, VA
    The propane ones are nice and are definitely convenient, but a gallon of Coleman fuel contains more energy per unit-volume than propane and leaves less of a carbon footprint because you end up throwing away more propane cylinders by the time you'd throw away one empty gallon can of white gas. Cost of white gas is cheaper too when you compare the number of BTUs you get from white gas vs. propane.
    I guess it is all a matter of personal choice.
    six5crèéd likes this.
  12. May 12, 2020 at 10:14 AM
    #1792
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  13. May 12, 2020 at 10:24 AM
    #1793
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Lol Spike
    Slashaar likes this.
  14. May 12, 2020 at 12:08 PM
    #1794
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I've got an idea what that is...
  15. May 13, 2020 at 4:32 AM
    #1795
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Now that he has revealed it, here's the rest of it :D
  16. May 13, 2020 at 8:04 AM
    #1796
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Nice!
    What machine are you running?
  17. May 13, 2020 at 8:04 AM
    #1797
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Trak DPM V5
    StayinStock and nagorb[QUOTED] like this.
  18. May 13, 2020 at 8:43 AM
    #1798
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    First manual style mill that I've seen with CNC capabilities. Nice. Wish I had one of those in the garage.
  19. May 13, 2020 at 10:59 AM
    #1799
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Installed. Thanks again! Love it!!
  20. May 13, 2020 at 11:12 AM
    #1800
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Looks good up there with the rest of the crew :thumbsup:
    Slashaar and StayinStock[QUOTED] like this.
