What have you powered with your truck bed outlet? - (2016+) Stock/OEM
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3_TACOS_NEVER_ENOUGH, Feb 12, 2018.
  1. Feb 12, 2018 at 3:23 PM
    #41
    AngryOscar
    AngryOscar Well-Known Member
    Ben
    Sumter SC
    2016 Silver Tacoma TRD OR Manual
    I used mine for an electric hedge trimmer. I I didn't have an extension cord long enough to reach the back far end of the backyard. Worked great.
  2. Feb 12, 2018 at 3:31 PM
    #42
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Really ? What hp was the house recirc pump ?
    MOC221_[QUOTED] likes this.
  3. Feb 12, 2018 at 4:05 PM
    #43
    The-Stig
    The-Stig Well-Known Member
    Kyle
    2017 TRD Off Road / Access Cab / Long Bed
    I'm wondering what the biggest air compressor you could run from this is. With no extension cord. I'll buy a longer air hose rather than using an extension cord. Anyone good at math able to match the draw to an available air compressor?
  4. Feb 12, 2018 at 4:32 PM
    #44
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Calculations are going to result in a conservatively small compressor most likely. To actually get close to the upper limit will require some level of testing.
    Would you need to compressor to be able to start at pressure? (To start running at 80 psi after shutting off and need to restart) or are you ok with the compressor only needing to start from 0 psi
  5. Feb 12, 2018 at 4:35 PM
    #45
    The-Stig
    Kyle
    0 PSI would be fine. I most likely wouldn't need it often, and would just blow off the extra PSI in the tank after I'm done using it. That's how I use my current air compressor which lives in the garage. I feel like the compressor will last longer if it stays at 0 psi when in storage. Less humidity in the tank, less pressure on the other components. Not sure if I'm right, it's just an instinct.
    tcjacado likes this.
  6. Feb 12, 2018 at 5:05 PM
    #46
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    ditto on the fuse question?
  7. Feb 12, 2018 at 5:16 PM
    #47
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I really don't know.. it's just a small circ pump for the hot water and I selected the low setting before firing the whole thing up lol
  8. Feb 12, 2018 at 5:16 PM
    #48
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
  9. Feb 12, 2018 at 5:33 PM
    #49
    Prairie Hawk
    Prairie Hawk Unknown Member
    North border of Weird
    2016 Silver DCLB OR
    SOS Concepts Sliders Softopper OVTune 87 iphone charger WeatherTech Floor Liners F/R De-badged Rear Differential Breather Mod
    I have used this compressor from Harbor Freight.
    3 gal. 1/3 HP 100 PSI Oilless Pancake Air Compressor
  10. Feb 12, 2018 at 8:23 PM
    #50
    3_TACOS_NEVER_ENOUGH [OP] Well-Known Member
    Various Locations: TX, CA, NC, AL, MS, and FL
    Oh dang, I have the same one!
  11. Feb 12, 2018 at 8:46 PM
    #51
    AWDDude
    AWDDude Well-Known Member
    2017 Tacoma TRD Off Road DCSB, QuickSand
    cheapo black and decker circular saw to cut some 2x4s. ran slower than normal but it cut just fine.
  12. Feb 12, 2018 at 8:50 PM
    #52
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Same. That actually works? You think it could inflate some 33's?
    Fastbilly5 likes this.
  13. Feb 12, 2018 at 11:35 PM
    #53
    1tacomaluvr
    1tacomaluvr Well-Known Member
    '17 Inferno OR DCSB
    A utility light (incandescent 60w) to work on the truck. But now I carry a 23w LED variant so the draw is less! Works.
  14. Feb 13, 2018 at 12:05 AM
    #54
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    During the Hurricane Harvey flooding we were without power for like 36 hours.
    It was able to run my 7 cu ft chest freezer (~medium size).
    I thought it was running my refrigerator: it was running the circulation fans, lights, ice and water dispensers; but, apparently the compressor was not running.
    My mileage took a big hit that tank.
    Rotekk likes this.
  15. Feb 13, 2018 at 12:06 AM
    #55
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    Not exactly the same but same output
    In my 2014 4runner i powered my dremel to cut some bolts off my roof rack
  16. Feb 13, 2018 at 12:38 AM
    #56
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    I charged my Dewalt 20v batteries for my impact,drill, skillsaw just fine. Also for the blower for inflatables mattress, pool floaters etc.
  17. Feb 13, 2018 at 6:03 AM
    #57
    BigWhiteTRD
    Ted
    I agree with storing empty, but it sucks when you turn on a compressor and it shuts off (at max psi), but won't turn back on until the pressure gets really low. That really sucks when driving nails, painting, etc... probably less irritating for tire pumping.
    So I tried my (about) 1 hp porter cable 6 gallon pancake compressor.
    https://www.amazon.com/PORTER-CABLE-C2002-Oil-Free-Pancake-Compressor/dp/B000O5RO1Y
    It will start and pump at zero psi and get up to about 70 psi before the compressor quits pumping... but it is NOT running right for any of that time. Motor is at 50% rpm at most.... but it did do it. I would not recommend except in emergencies, but it did work for me to 70 psi...20180213_085131.jpg
  18. Feb 13, 2018 at 6:19 AM
    #58
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    I've run my shop vac off it. It works for a bit, then quits and I have to reset the switch to get it going again. Easier to run an extension cord to a wall outlet.
  19. Feb 13, 2018 at 6:40 AM
    #59
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    When I first got my truck and started camping more often, i used the inverter for a coffee grinder and a electric kettle. As time moved along, i decreased the amount of kit I carry and so now i use a manual grinder and biol water on my camp stove instead. Thats all ive ever plugged in to the inverter. If it were in the cab, I would probably use it more often to charge stuff while we drive....
  20. Feb 13, 2018 at 7:52 AM
    #60
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Like others, I mostly charge batteries while driving (100W mode) but did run a 7-1/4”circular saw to cut some redwood fence posts (4x4, two passes to make each cut) with no problem. I recently got a cordless circular saw ... best tool ever! FWIW, the idea of the inverter and outlet seemed really cool when I got the truck but in reality I’ve used it maybe half a dozen times.
    bush rat and tcjacado like this.
