What have you turned off on your Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bmg88201, Jan 13, 2023.
  1. Jan 15, 2023 at 10:40 AM
    #101
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    This statement right here is totally amazing to me. I work hard and deeply value my salary, and one needs to shell out a lot of bucks for a brand-new vehicle (and I paid cash for my Tacoma). It is unconceivable to me that I could ever make that sort of investment and not know everything about the car/truck I'm buying. In fact, I have never met a salesman that knew more about the vehicle I was buying than I did. I'm not like this with routine low-cost items but would feel like I cheated myself if I didn't do my research for high-cost items. Like someone else mentioned already, it is extremely rare when the average driver could ever out react these systems so by disabling them you are putting yourself and others potentially at risk which is also a selfish and somewhat foolish behavior. Oh, and reflexes don't get better with age either, otherwise formula 1 drivers would all be senior citizens! The real kicker here is that these fantastic systems require absolutely zero effort or adjustment by the driver (I'm referring to on-road driving of course). After reading how many of you disable LDA I realized there is only one reason (again on road driving), you are incapable of keeping your vehicle between the lines and that right there is very telling, because if you did you would never know the system was operating!
  2. Jan 15, 2023 at 1:09 PM
    #102
    bmg88201
    bmg88201 [OP] Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Opinions and butt holes …….. you know the rest
    baldguy111, vanderww and wayupnort like this.
  3. Jan 15, 2023 at 1:58 PM
    #103
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    Under hood fuse box. Note that you'll lose your bluetooth mic which goes through the telematics unit. The telematics unit has a backup battery which will run down after a bit. Then you'll see the DCM icon on the head unit greyed out and the SOS light in the overhead console go dark.
    Toycoma2021[QUOTED] likes this.
  4. Jan 15, 2023 at 6:33 PM
    #104
    Taco y mas
    Taco y mas Well-Known Member
    SoCal
    Tacoma TRD Sport
    None
    You are not wrong. But some men you just can't reach.
    BC Hunter likes this.
  5. Jan 15, 2023 at 6:48 PM
    #105
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    +1
  6. Jan 15, 2023 at 7:19 PM
    #106
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i turned off LDA simply because it's only a beeper tone. if it vibrated the wheel/seat i'd leave it. the beep is the same beep for the a number of other vehicle functions like rev limiter, brake warning, and seatbelt warning. so anytime it goes off, it's a roulette of 'which system activated it?' and i've got to look away from the road, focus on the gauges, read the gauge display warning, then look back up. my brake warning goes off sporadically, i call it my 'ghost detector'. leaving LDA on just means i'm trying to figure out what's causing the beep longer than immediately understanding the issue the truck is trying to warn me about, and i can issue the correction.
    so i argue LDA in it's present form in my truck actually makes me a more hazardous driver due to the poor integration and awareness techniques implemented.
    rkd1119 likes this.
  7. Jan 15, 2023 at 7:33 PM
    #107
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Be assured: I can tell you from personal experience that at least the stability control systems work. I was driving my Dad in his Cadillac one time on a straight piece of wet slushy road when when the rear end of it suddenly "stepped out" to the left at only 30 mph with no warning: black ice. Immediate reaction from my experience was to counter-steer into the skid.... EXCEPT this Caddy was Front-Wheel-Drive...... Before I had a chance to react or even apply the remedy, it was like a Guardian Angel reached down and pulled the rear-end back in. I'll never forget it. It makes a believer out of you. Saved a likely spin-out on a ditch and tree-lined road. I think it was a 2005.
    My Tacoma has sent warnings to me occasionally via the flashing stability control lamp: I can live with the "spying".
    BC Hunter and Bcjammerx like this.
  8. Jan 15, 2023 at 7:53 PM
    #108
    OldSaltyDog
    Hampton Roads VA.
    Yeah, I get it, it's really hard to tell whether the chime your hearing is your engine over revving (because how would you know that otherwise?) I mean we rarely have full control of our foot on the accelerator pedal right. Of course, if your seatbelt miraculously comes loose how would you know, we know that happens ALL the time doesn't it!
    If your brake warning goes off sporadically you might want to have that looked at before it gets worse.
    Is there a sarcasm font here?
  9. Jan 15, 2023 at 11:21 PM
    #109
    NightHawkTaco420
    NightHawkTaco420 Well-Known Member
    DFW, TX
    2017 SR5 Access Cab
    - Ceramic tinted windows all around - Morimoto XB headlights - Spyder tail lights - TRD grill - TRD OR charcoal/machined wheels - interior chrome delete - interior LED bulb switch - weathertech mats (F/R) - MESO Customs Ultimate 3rd Brake Light (BD3 Model) - Tuff Skinz Door Sill Protectors Planning a 3/1 lift/level project and a few other future mods
    holy crap this made me lol!!!!!!!!!!!!!
  10. Jan 15, 2023 at 11:50 PM
    #110
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Shark fin gets me great FM radio reception, I'm happy with that. I didn't want the nanny crap that came on this truck but I admit I use some of it now. Just today I was driving down the highway eating pizza with the radar cruise set at 80 mph and LDA on. I felt much safer steering with my left knee knowing the truck would beep at me if I swerved and would slow it's self down before I ran over a subie full of stoners going 45. So yeah, some of this stuff is nice.
  11. Jan 16, 2023 at 1:08 AM
    #111
    chinoxmk22
    chinoxmk22 Well-Known Member
    Mario
    2023 Tacoma
    I’ll be doing the same in another month
  12. Jan 16, 2023 at 7:32 AM
    #112
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Me to salesman - “hey, I kind of like that silver one over there…” :)
    Imagine my surprise when I got home and discovered it was the SR Access cab Utility package and didn’t have a back seat.
    soundman98, BattleKat and musicisevil like this.
  13. Jan 16, 2023 at 7:50 AM
    #113
    BillyE
    BillyE Well-Known Member
    Exactly what I'd want if they made it with a manual transmission (either engine--I don't really care)
    davidstacoma[QUOTED] likes this.
  14. Jan 16, 2023 at 7:55 AM
    #114
    davidstacoma
    David
    NC
    3 years later and I still love this truck, exactly what I wanted, so much room in back behind the front seats for when I moved plus the 6 ft bed which was a must. Other things I wanted I just added- fog lights, intermittent wipers (lol this is truly the only thing that surprised me), keyless entry, led dome lights so I can see stuff in the back, etc.
  15. Jan 16, 2023 at 8:12 AM
    #115
    10ptXtreme
    10ptXtreme Well-Known Member
    NJ
    2020 DCSB TRD Sport Voodoo Blue
    How are you guys turning off that seatbelt chime? I want to turn off mine in my 2020 Tacoma.
    David
  16. Jan 16, 2023 at 8:17 AM
    #116
    AmateurTaco1313
    AmateurTaco1313 Dreaming of the next build
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    As I was hating on this thread, confused as to why it got stickied, I then realized I don’t use the lane assist, my BSM stopped working, I don’t use the Qi charger, or the radar cruise control, and a tune made the ECT obsolete…..damnit I’m part of the “turn shit off” group.
    and since I don’t listen to the radio at all the shark fin may go away soon…
    soundman98 and LooneytuneSR5 like this.
  17. Jan 16, 2023 at 8:18 AM
    #117
    erwigg
    erwigg Well-Known Member
    Eric
    Oregon Coast
    2022 Tacoma access cab SR
    The SR have alot of those same features:
    LDA
    *BSM
    *PCS
    *Auto High beam
    Sirius radio,
    Radar Cruise Control.
    soundman98 likes this.
  18. Jan 16, 2023 at 10:28 AM
    #118
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
  19. Jan 16, 2023 at 10:37 AM
    #119
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    People still listen to AM/FM?
  20. Jan 16, 2023 at 10:41 AM
    #120
    BattleKat
    San Diego
    Your BSM stopped working? Did you get a lift? I like the verification light being off when I change lanes. I was driving in heavy rains yesterday in the dark. It was hard to see cars around me even with their headlights on. Sadly, I think the heavy rain caused BSM to not work as well, there were several times I knew cars were in my blind spot and the light wasn't coming on.
    Did you ever get it checked out?
