What have you used your bed outlet for?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrFunker, Jul 14, 2014.
  1. Sep 19, 2014 at 7:25 AM
    #61
    dino velvet
    dino velvet Member
    San Antonio, TX
    07 Prerunner sr5 TRD
    I've planned on plugging in a blender to make frozen margaritas after a mountain bike ride, but should probably try it out first around the driveway to see if it will power it...:eek:
  2. Sep 19, 2014 at 2:19 PM
    #62
    1980
    1980 Well-Known Member
    The Dust Bowl
    Most consumer-level solid state DC to AC inverters that I tested when I was in electronics school produced a stepped square wave versus a true sine wave so I would presume that the Tacoma's inverter does too. I don't have access to an oscilloscope anymore (can't justify spending a thousand dollars for even a cheap one to use as a hobby) so I cant test for sure.
    I just went back over and tried some other stuff at the shop to see if it would run. I found a few things that seem to run just fine on the Tacoma's inverter. As you will notice, these are mainly high-rpm/low-load tools with universal motors.
    Nothing much with an induction motor or a universal motor over 1 horsepower worked right, if it turned at all. However, the following all worked like a charm:
    3/4 horsepower angle grinder (unless you press hard)
    150 W halogen work light
    Random orbital sander
    Dremel moto tool
    Oscillating room fan
    Hot glue gun
    DeWalt 12 V charger
    3/8" drills work but don't have a lot of torque. For instance, I could drill 1/4" holes and drive 2 1/2" deck screws into soft pine but the drill bogged down when trying to drive lag screws.
  3. Sep 19, 2014 at 2:42 PM
    #63
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    TRD Blown with AFE Stage 2si CAI...
    and on..and on..and on...
    you can click on Blue truck info at bottom of profile to see some of the Mods ...
  4. Sep 19, 2014 at 2:47 PM
    #64
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    I use mine for the hedge trimmer a lot.
  5. Sep 19, 2014 at 3:00 PM
    #65
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Use mine to run an Air Compressor .
  6. Sep 19, 2014 at 3:10 PM
    #66
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    I use mine to run my Traeger Smoker .... meals on wheels
  7. Sep 19, 2014 at 3:35 PM
    #67
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Electric chainsaw last weekend.
  8. Sep 19, 2014 at 3:42 PM
    #68
    craigb
    craigb Well-Known Member
    Craig
    Pa
    2013 TRD Sport
    Leer Cap Bilstein Shocks under bed lighting all weather mats window rain guards bed mat
    Sawzall, soldering iron, dremel tool, charge hand tool batteries,
  9. Oct 27, 2014 at 8:34 PM
    #69
    Bewbs
    Bewbs New Member
    I've used it to charge up the RV, run sump pumps during a power outage, sawzall, electric rototiller, LED work light and even LED Christmas lights.
  10. Oct 27, 2014 at 9:18 PM
    #70
    sde780
    sde780 Well-Known Member
    Hmm some people can't even power a drill with theirs, while I've used mine with an electric chainsaw to cut 4" thick limbs with ease...
  11. Oct 28, 2014 at 7:40 AM
    #71
    DarthTarmac
    DarthTarmac Well-Known Member
    Craig
    Paducah KY
    Lifted, 33'd, and Murdered
    TRD Off-Road Package, Method Mesh 17x8.5 0 offset, Toyo Open Country AT2 285/70/17, Bilstein 5100 front and rear, OME 885, Wheeler's Progressive 3 leaf, OME Driveline Carrier Bearing Drop Kit, Depo black housed head lights, OEM 2011 TRD Sport grill color matched, Toyota accessory skid plate, bed linered rear bumper, black Kuat NV, Tepui Kukenam Sky RTT
    I finally used mine this weekend to blow up and air mattress whilst out camping.
  12. Oct 28, 2014 at 9:15 AM
    #72
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I used it to run a few things in the house the last time the power was out.
  13. Oct 28, 2014 at 10:23 AM
    #73
    BYBO
    BYBO Well-Known Member
    Byron
    Indiana
    My wife uses it for her marital aids.
    (No she doesn't)
  14. Oct 28, 2014 at 12:28 PM
    #74
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Used mine with my air compressor to fill the tires back up after some wheelin.
  15. Oct 28, 2014 at 2:12 PM
    #75
    guitars&tacos
    guitars&tacos Well-Known Member
    North Metro Atlanta
    2018 White TRD 4x4 Off Road 6 MT
    I play guitar so.I have plugged my amp in and jammed before. Pretty cool.
  16. Oct 28, 2014 at 5:59 PM
    #76
    orangeglo
    orangeglo ¯\_(ツ)_/¯
    Los Angeles, CA
    2011 DCSB OR
    Which chainsaw were you using?
  17. Oct 28, 2014 at 6:11 PM
    #77
    orangeglo
    orangeglo ¯\_(ツ)_/¯
    Los Angeles, CA
    2011 DCSB OR
    I used my outlet the other day with a hot glue gun to tack some thinsulate to my roof.
  18. Oct 28, 2014 at 6:34 PM
    #78
    mcmnos4r2
    mcmnos4r2 RLM sign group
    ny
    08 Double Cab TRD Sport w/ 6' bed
    Fuel krank 17 inch rims, cooper 285 70 17 discover atp tires. Old man emu 885 springs, 5100 shocks, 2 inch add a leaf and ended bilstein shocks. 7 Inch pioneer 200 bt touch screen, head rest 7 inch monitors. Full bed leds.
    After hurricane sandy hit long island, my house was out of power for over a week. Until I got my hands on my brothers generator it powered a laptop to play dvds for my kids as well as a tabe lamp at the same time.
    Also used it on on the side of the road to cut off my tailpipe after it was squashed flat after getting rear ended. I just happen to buy the sawzall that day!
    Drill and hammer drill, jig saw, while installing signs.
    I also have a larger 1600 Coleman. I use connected to my battery for larger tools.
