What head light bulb/led do i need for white light?
Discussion in 'Lighting' started by Ken b, Jul 2, 2014.
  1. Jul 2, 2014 at 7:01 AM
    Ken b
    Ken b [OP] Well-Known Member
    Ken
    Surprise, Az
    14 offroad 4x4
    ARE shell, bedrug, TRD wheels
    So last night i took my truck out back and was out past dark. This was the first time I took it out since I installed my light bar. i found that the stock amber headlight color was less than desirable compared to the white light of my LED bar.
    So now I would like to change my headlight bulbs to bring the color in line with the LED light of my light bar. As so many of you have probably already changed head light bulbs, what did you do with? Fwiw I don't want to go to projectors.
    Also, if there is a good suggestion for doing the same to fog lights i would appreciate that info too.
    Thanks
  2. Jul 2, 2014 at 8:49 AM
    NolaTaco42
    NolaTaco42 Well-Known Member
    New Orleans
    08 PreRunner
    4" lift 17x9" XD Hoss wheels on Nitto 285/70/17 Trail Grapplers
    5k is usually close to the led output with HIDs
    if your going led bulbs then get 6k.
  3. Jul 2, 2014 at 9:24 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I stuck Lifetime LED lights in my tacoma for both the headlights and fog lights. So far I love them! I've had them for about 3 months with absolutely no issues. They offer free lifetime replacement if the lights ever stop working, which is a big benefit to me and really helped me swallow the high initial cost. They are MUCH brighter than stock on my 2013 Taco and still have a very good cutoff. The color is pure white! They match perfectly to the rigid dually lights have have stuck on my bull bar.
    Here's a review of them on here.
  4. Jul 2, 2014 at 11:02 AM
    Ken b
    Ken
    Surprise, Az
    14 offroad 4x4
    Thanks folks, I just ordered the Lifetime LED.
  5. Jul 14, 2014 at 3:59 PM
    J ROC
    J ROC Member
    '13 PreRunner Black
    Debadged LED Light interior
    Which bulbs are for the fog lights? Are they the H11?
  6. Jul 14, 2014 at 4:15 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    white light is not better to see with... there are no facts from any credible scientist that will support the claim and it's all in your head.
    any bulb with a tint on it won't be brighter it just shades out the other colors (less actual light).
    yellow and green light are the best spectrum's to see in and you just blocked them
  7. Jul 14, 2014 at 7:19 PM
    Ken b
    Ken
    Surprise, Az
    14 offroad 4x4
    Who said white light was better? I just wanted to match the color of my LED bar.
  8. Jul 14, 2014 at 9:42 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    You sir, are incorrect about white LED's being less bright than other forms of LED. Yes tinted filament bulbs block out light which lowers the observed lumen of any filament bulb, but LED's work with a luminescence and phosphorescence emission that is not in any way similar to a filament light bulb. The phosphor "blocks" the waves emitted, but it releases the energy it absorbs in another part of the light spectrum. Think glow paint. In some cases this efficiency surpasses even CCFL's that emit white. The trick with LED's is getting enough power into the thing in a fairly stable fashion without blowing it out.
    White light is actually an amalgamation of all of the colors of the spectrum that our cones can see mixed together. So this is why it is difficult to make perfectly white light, you need a material to emit at least three high peaks of light.
    Anyways, if you look at a LED spectrum chart for a typical non RGB white LED this is what the white light is made of:
    As you can see white LED's actually throw off a fair bit of light in the yellow and green portions of the spectrum. There area's that white LED's are weak at emitting is the 500 nm trough (light blue/turquoise) and anything over about 600 nm (orange and red). While blue is the largest luminous source total luminescence is achieved by spiking all three of the cone types that our eye's see, hence our minds perceive it as white.
    A yellow LED phosphor will give similar output to a white phosphor, all depending on the efficiency of the phosphor chosen of course. Most original LED blubs where red since that was the most efficient color. Now all colors can be made relatively efficiently using phosphors, other than purple. Right now the hardest primary color to get a good yield from is blue, hence why blue LED's are not common in lighting applications. That being on top of the fact that perceptively cool colors are not as well translated by our brains in dark environments.
  9. Jul 15, 2014 at 10:36 AM
    XXXX
    sKiP
    05 Prius
    No one was comparing LED's to LED's but thanks for wasting your time.
  10. Jul 15, 2014 at 4:12 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Um...Gee whiz :rolleyes:......what color is sunlight? :confused:
    Oh that's right....it's WHITE :eek:
    I'm not expert on the human eye, but I would suspect that our eyes have evolved/adapted/been divinely engineered, to see the best in sunlight which is white and is comprised of a mixture of all colors seen in the same proportions present in a typical rainbow.
    I agree that it's kind of silly to put blue glass on some halogen bulbs to filter out the yellow light so they appear more white. This also makes them run hotter and decreases their longevity.
    I would think however, that pure yellow or pure green light would make it kind of difficult to distinguish certain colors from other colors. The last time I checked, I didn't see too many cars with emerald green :D or canary yellow :) headlights.
    I think Sterdog's post was interesting and informative especially since LEDs were part of the subject of this thread. I would like to thank him for sharing. :D
  11. Jul 15, 2014 at 4:37 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    The OP bought White LED's. You called him stupid for buying them. I pointed out you needed to read the thread, since he did not buy coated halogen bulbs, and I gave you some good information on LED lights. Jerk :p.
  12. Jul 15, 2014 at 4:51 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Tell 'em dog...:cool:
    Dang, I thought after 3 strikes you were out....This guy (XXXX) must be reaaally out there. :goingcrazy: :rofl:
    :stirthepot:
    :argue:
  13. Jul 16, 2014 at 9:11 AM
    Northernlights
    Northernlights Active Member
    Rich
    CT
    2013 DCLB SR5
    Leer Cap
    Sterdog , thank you for the very informative post .
