What I discovered on the oil level/capacity
Discussion in '4 Cylinder' started by The Shape, Sep 3, 2009.
  1. Sep 3, 2009 at 11:55 AM
    The Shape
    The Shape [OP] Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    I know the actual amount of oil the 2.7 holds with a filter change has been debated on this site quite a bit. I thought some might be interested in what I came up with. My 2009 tacoma hit 4,900 miles today and decided to change the oil. First thing I did was check the level with the factory fill. From the factory my oil level read about a 1/4 inch above the top dot on the dipstick. I used a file to scribe a line on that spot.
    I then proceeded to change the oil. I pulled the drain plug and filter and let it drain for approx. 30 minutes. I then installed a Pure One filter #PL10241. To bring it back up to the line I scribed the truck indeed held a full 6 quarts of oil. I used Castrol GTX 5W20 oil. So these are my personal results. Don't know if this helps anyone, but thought it worth posting.
  2. Sep 3, 2009 at 11:57 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I think much of the debate was actually related to the 4.0 Liter V6 engine.
  3. Sep 3, 2009 at 12:01 PM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    Actually the main debate is with the I4. The results are interesting. That means the spec is correct and the stick is wrong. It would also mean that any dealer that automatically does 5 quarts is under filling by a full quart.
  4. Sep 3, 2009 at 12:02 PM
    The Shape
    Forrest City, AR
    True and on '07 which I used to tae to the dealer, the receipt always showed 5 quarts.
  5. Sep 3, 2009 at 12:36 PM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    Thats not necessarily a bad thing. Having the oil a quart low will cut down on windage losses. You'll pick up a few ponies.
  6. Sep 3, 2009 at 12:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You really think 1 quart (about 1/4" in the pan) would give a "Few hp" gain? :rolleyes:
  7. Sep 4, 2009 at 12:28 AM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    I rather have a little more than not enough, without damaging the seals of course. My supercharged (raced hard) Prelude always gets more oil than spec.
    So I just brought my brand spankin new 4 cyl Tacoma home - factory fill is way above the second dot. And that's after 60 miles and at least 10-15 WOT pulls to redline. I love this truck btw.
  8. Sep 4, 2009 at 4:29 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yep, I think that's exactly what it comes down to. Bet the next Gen Toyota has this fixed....they read these boards ya know.
  9. Sep 4, 2009 at 5:55 AM
    The Shape
    Forrest City, AR
    YES the 5.0 Fox body stangs had the same problem, having owned several of them this isn't a new issue to me LOL. The concensus on the 5.0 boards is that you just pour in 5 quarts of oil as the manual calls for and put a new mark on your dipstick.
    Another thing I noticed is that my wifes Yaris reads over the full mark by about the same amount my tacoma does when using the amount of oil called for in the manual (4 qaurts).
    Also you would have to add a WHOLE lot of extra oil to start blowing out seals. Oil pressure is what would blow out a seal and no matter how much oil you pour in, your oil pump and tolerances in the engine are only going to build so much pressure. The concern is adding so much that the crank is splashing around in it. I HAVE had an oil filter explode on an engine , but that was because the bypass spring in the oil pump malfunctioned not because it had to much oil in it.
  10. Sep 4, 2009 at 6:43 PM
    Plain Jane Taco
    Plain Jane Taco You....out of the gene pool.
    Bill
    USA
    2015 SW DCSB TRD Sport PreRunner
    At least you got the goods right. I been using this combo on all of my vehilces for as long as I can remember. Never an isse. :thumbsup:
  11. Sep 8, 2009 at 5:20 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    5 quarts to get over the low line, 6 quarts to the top. That's what I've found, really either will work fine.
  12. Sep 9, 2009 at 5:22 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I just did my first oil change this weekend and 6 qts filled it back up to the pre oil change level.
  13. Sep 9, 2009 at 5:30 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    LOL, if so then you'd think they wouldna went 5 years puttin on shitty leaf springs on the back of them or several years worth of frame weld issues or several years of folding tailgates. If they are reading them it would be to fuck modders on warranty issues or to see just what crap they can get away with. Highly doubt anything would be used to improve the customer experience unless they were facing lots of lawsuits.
  14. Oct 20, 2010 at 11:21 AM
    Dudley
    Dudley Cranky Old Bastard
    David
    Texas
    10 Access Cab
    I am on the "free oil change plan". Just took mine into the dealer for the gas pedal recall issue and first oil change. Told the service assistant not to over fill the engine. Got it back and it was slightly over the full mark. Guess the big T just loves giving away oil. Incidentally, ticket indicated 7 quarts?!
  15. Oct 20, 2010 at 3:37 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    These days I just buy a 5 qt jug of whatever at Waldo-World, and it along with a PUre One it comes up to just below the line. Has not moved during 5K OCI's.
  16. Jan 27, 2011 at 11:18 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    Just below which line? The low mark or the full mark?
  17. Jan 27, 2011 at 3:04 PM
    91r100gs
    Dan
    Kansas City area
    The full line. 4 more oz will make it hit the full line
  18. Jan 28, 2011 at 6:45 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I buy a 5+ container of mobil 1 and its perfect for mine. The plastic mobil 1 container states that it is 5+ quarts
  19. Feb 1, 2011 at 8:50 AM
    Dudley
    David
    Texas
    10 Access Cab
    I can't really understand the obsession to make sure that the oil is just up to the full mark on the dip stick. I guess if you had a leaky engine and didn't want to bother checking the oil every time you started the motor I could understand wanting to have the oil right up to the top without being overfilled. Since the two marks are intended to be a reference to the level in the engine, and as long as the oil falls within the two reference marks I would think the engine would be perfectly happy. It is the overfilling and seal blowing that bugs the hell out of me.:mad: If I could just convince the dealer to put 5 quarts in and leave it that would be great!
    JMHO you understand.
  20. Feb 2, 2011 at 6:12 AM
    KentuckyEd
    KentuckyEd Member
    Ed
    Louisville, KY
    2012 std cab 4X4 2.7L auto
    Correctly defining the fill level (and keeping the oil at that level) is beneficial for engine cooling in high load operation where the oil can help dissipate heat. I certainly agree that overfilling is bad, but if 6 is the "correct" amount then running one qt low means you have 17% less fluid to handle the lubrication function. That doesn't appear to be optimal.
