What I have learned about 3rd gen transmission.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by particleman, May 1, 2017.
  1. May 1, 2017 at 3:32 PM
    #121
    ToyoMann
    ToyoMann Well-Known Member
    2017 Tacoma TRD Off Road
    There are some values that need to be cleared with the Techstream.
  2. May 1, 2017 at 3:33 PM
    #122
    ToyoMann
    And it is an exceptionally smooth, continuous system.
  3. May 1, 2017 at 3:37 PM
    #123
    dsmdylan
    dsmdylan Well-Known Member
    Dallas, TX
    '17 DCSB OR Quicksand
    That is exactly what the term Atkinson Cycle refers to, and has always referred to. They're not claiming it's an actual Atkinson engine from the 1800s, obviously. Toyota has been using it since the Prius came out in the '90s and several other automakers use it as well, almost exclusively in hybrids. It was never marketed as strongly as it has been with the Tacoma because, probably, hybrid owners don't care about engine technology. If your claim is that being in the Atkinson cycle doesn't reduce power output, you don't really understand what it's doing in mechanical terms.
    The difference between my claim and the claim that there's a problem in the valve body that results in a bubble, or whatever, is that every bit of marketing and technical documentation about this truck indicates that it uses the Atkinson cycle and, if you understand how it works, logic dictates that when power output is at a minimum is when it's active. Therefore, my claim is self-evident.
    Here's something else that's self-evident: by the time you give enough throttle for it to get out of Atkinson, you're also giving it enough to downshift out of OD.
    TheCookieMonster likes this.
  4. May 1, 2017 at 3:46 PM
    #124
    ToyoMann
    You are partially correct. See the below link for a description of the Atkinson cycle. I would not use Wikipedia or magazine articles for your facts. There is a lot of marketing jargon in there. See the patent.
    Atkinson cycle:
    https://www.google.com/patents/US367496
  5. May 1, 2017 at 3:48 PM
    #125
    ToyoMann
    And you are correct, when the intake camshaft is at maximum retard, what you are calling Atkinson cycle, the torque is minimal.
    Of course I understand that DSM. I just explained the whole system off the top of my head.
  6. May 1, 2017 at 3:51 PM
    #126
    dsmdylan
    Dallas, TX
    I am fully correct, you're not teaching me anything. This patent is for an Atkinson engine. Toyota does not use an Atkinson engine. They use an Atkinson cycle which mimics the valve timing of an Atkinson engine but has nothing in common with the engine design, otherwise.
  7. May 1, 2017 at 3:53 PM
    #127
    iyapysnf
    iyapysnf Well-Known Member
    2016 DC OR M/T
    I know, not sure why everyone says the transmission hunts all the time. Mine goes into a gear and stays there just fine. ;)
  8. May 1, 2017 at 3:56 PM
    #128
    ToyoMann
    I stand corrected. You are correct in your above statement. I was not aware that the Atkinson cycle term could be used to describe the new vvti strategies.
  9. May 1, 2017 at 3:58 PM
    #129
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    Ever drive up a mountain?
  10. May 1, 2017 at 4:00 PM
    #130
    iyapysnf
    2016 DC OR M/T
    All the time. I live in Utah
  11. May 1, 2017 at 4:43 PM
    #131
    bensonxj
    bensonxj Well-Known Member
    2016 DCSB TRD Sport
    He has a MT so not relevant to AT conversation.
    Joe D likes this.
  12. May 1, 2017 at 5:03 PM
    #132
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    Pull it and report back if it sucks less.
  13. May 1, 2017 at 5:06 PM
    #133
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    POS truck, fuck Toyota.
  14. May 1, 2017 at 5:09 PM
    #134
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    This is a great resource, Ill spend some time going thru this thank you!
    Look man you obviously understand the method of variable valve timing in this truck, but when you state that these trucks won't accelerate in 5th gear because it's permanatly in an atkinson cycle condition, I get skeptical. I asked you to provide me with something technical to back it up, and you say that you can literally feel it. I get skeptical x2.
    Speed limit on the highways here is 60mph, so I doubt i'll get to test your theory any time soon. All i'm saying is
    my drive by wire truck howls, the hood shakes, pedal buzzes, interior rattles, and it makes it hard to "feel" anything so "self evident" as what you're describing. Luckily black sabbath at about 40 on the volume knob has made this truck much more enjoyable in any gear.
    Riding Dirty and ToyoMann like this.
  15. May 1, 2017 at 5:48 PM
    #135
    ToyoMann
    Also,
    I am pretty sure (this is speculation) that the truck does not take discrete steps into an out of Atkinson. I think it is a continuous movement of intake camshaft position. The transition is very smooth. I have been meaning to capture a data log on the Techstream but I've been very busy.
  16. May 1, 2017 at 6:13 PM
    #136
    oldschoolczar
    '16 DCSB TRD OR
    Yeah but, you ever drive up a mountain... on weed?
  17. May 1, 2017 at 7:40 PM
    #137
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
  18. May 1, 2017 at 8:10 PM
    #138
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Who's that guy in the bushes?? RED TEAM GO, RED TEAM GO!
    oldschoolczar[QUOTED] likes this.
  19. May 2, 2017 at 7:13 AM
    #139
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    Thats what I figured.
    Just picked up my truck from having an oil leak fixed and I'm 99% sure the battery was unplugged due to the fact that my trip was back at 0 and it still drives like junkish. But I will try anyways!
    smitty99 likes this.
  20. May 2, 2017 at 9:11 AM
    #140
    Aspie83
    Aspie83 Well-Known Member
    2016 OR AC MGM
    This is spot on. It seems rare for anyone complaining about a "gutless" engine or a lousy transmission to reference the Atkinson cycle. No one should have bought this truck expecting a completely traditional driving experience. Not with an engine that deliberately reduces its effective displacement when cruising. It may be, as you suggest, that a lot of people didn't understand this, or it could also be that they did understand it but bought the truck anyway, somehow expecting that it wouldn't matter. This is a Toyota Tacoma, after all, and, well, Toyota wouldn't really do this to its loyal fans, would it? They did, but no one should say they didn't make the Atkinson cycle clear to anyone who read the marketing tracts, and the implications of it should have been evident. It may be that Toyota didn't do the best job of coordinating the transmission software to the Atkinson engine, but smoothing out the engine's Atkinson cycling via a transmission would probably cancel out the fuel savings. And I had expected those fuel savings to be better than they turned out to be. With a lower displacement engine, significantly reduced wind resistance, and the Atkinson cycle, I thought we'd see a few more MPG. But the EPA data should have dashed the expectations of anyone like me. So all the information was available before the truck came on the market. Do I like it? Not particularly. But I've adjusted over time. I just hope Toyota didn't change anything that compromises reliability and longevity. That's really why I bought this truck as compared to a different one.
