What I learned today.
Discussion in 'Off-Topic Discussion' started by kd8awe, Jan 25, 2011.
  1. Jan 25, 2011 at 4:07 PM
    kd8awe
    kd8awe [OP] Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    First off... I am NOT a plumber by trade. With that said, my house is about 55 years old. I had a drain pipe in the kitchen break. I have been in the process of re-engineering the drain pipe and switch it over from metal to PVC. All the other drains in the house have been re-plumbed to PVC.
    Anyhow in order for me to fit the 1 1/2 PVC I have to drill some new holes with a hole saw and a right angle drill. That goes better than expected. Next I need to cut an access hole in the floor (under the kitchen cabinet). This can only be done from the basement. I locate the area. It is between the hot and cold water feed lines. I need about a 4 inch square hole and I have about 6 inches of room to do this. Now the fun starts. I grab the trusty Sawz-All and get to cutting. I finish my cuts and step back to admire my work when... I hear a faint hissing sound. Then the dripping starts. You guessed it, I nicked one of the water feed lines. I look at the feed line and it looks like a scatch with just a pinhole of a hole in it. Well now I get to practest my copper pipe repair. Plumbing sucks.
  2. Jan 25, 2011 at 4:10 PM
    Average JOE
    Average JOE Well-Known Member
    San Diego
    PreRunner
    3'lift,Upgraded sound system,Dyanamat interior flowmaster,K&N,
    Some times knowing how not to do something is a great tool. Good luck with the home repare.
  3. Jan 25, 2011 at 4:12 PM
    jandrews
    '09 FourDubDee TRD OR
    Just put some saran wrap over the hole.
  4. Jan 25, 2011 at 4:15 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Turn the water off at the valve, and solder the hole, easy fix if you can get to it.
  5. Jan 25, 2011 at 4:16 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Home depot sells a a DIY kit with the torch, solder, flux and what not. It's actually really easy.
  6. Jan 25, 2011 at 4:18 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  7. Jan 25, 2011 at 4:19 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    if you do not want or know how to use a torch...dont burn the house down
    that being said you can use a compession fitting... no soldering involed
    shut water cut pipe slip over pipe tighten nuts
  8. Jan 25, 2011 at 4:20 PM
    lcogginz
    lcogginz Well-Known Member
    Lauren
    SC
    2010 TRD Timberland Mica DC OR
    Good luck. If it makes you feel any better my husband is a commercial plumber by trade, and he hates it too. ;)
  9. Jan 25, 2011 at 4:22 PM
    kd8awe
    Rocky
    Ohio
    4x4 TRD Off Road
    I have all the tools I need....That, I think is how the problem started. LOL I am not afraid to jump in and try something. At least you learn how NOT to do something. lol I counted all my fingers before I started and I ended with the same amount. The worst thing is my girlfriend won't stop laughing !
  10. Jan 25, 2011 at 4:27 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    ok just make sure
    1 you dont burn the house down...
    2 make sure all pipes n fittings are clean
    dont over heat it and use flux
  11. Jan 25, 2011 at 4:32 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  12. Jan 25, 2011 at 6:10 PM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    Duct tape fixes everything...
    :cool:
  13. Jan 26, 2011 at 2:29 AM
    Average JOE
    San Diego
    PreRunner
  14. Jan 26, 2011 at 3:56 AM
    forestgreen99
    forestgreen99 Member
    as east as you can get in North America
    1999 taco v6 4x4
    OME nitrocharger sports, 882s, Dakar leafs, ARB bumper
    should have used a 4" holesaw. lol
