What inner CV grease should I use?
Discussion in '1st Gen. Tacomas (1995-2004)' started by clothar, May 10, 2013.
  1. May 10, 2013 at 2:28 PM
    clothar
    clothar [OP] Well-Known Member
    Vancouver
    98 V6 4WD Xtra Cab Limited
    Hi Guys,
    So my inner CV boot was slinging grease I checked the boot out it was not ripped or torn so I replaced the outer clamp where the grease was coming from and decided to replace the grease inside the boot because i had no idea how long it had been slinging grease.
    I bought some all purpose molyslip grease NGL2 cuz it says on the tube idea for: CV joints and other stuff.
    So I take off the inner clamp and a whole bunch of greyish liquid pours out which is much thinner that the molly grease that I have to replace it. So I research it on here and the thicker molly grease goes on the outer boot and the thinner grease or oil goes on the inner.
    The Toyota dealer here does not just sell the inner grease so I would have to get the boot kit which is $88.00 for a single boot kit even tho I just need the grease. I know they rake us over the coals in Canada.
    So I hoping someone knew what I can use instead. Cuz i really do not want to pay 88$ for some grease.
    Ideally i want people to tell me it is ok to use the molly grease I have cuz then i can fix it right now which would be great!
    Thanks guys,
  2. Nov 20, 2014 at 6:39 AM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
  3. Nov 20, 2014 at 6:41 AM
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    Interested in this and driveshaft grease
  4. Nov 20, 2014 at 6:53 AM
    htgreen3
    htgreen3 Well-Known Member
    Central Virginia
    2015 TRD OR
    Have not had my Tacoma long enough for CV joint problems, but on my Subaru I have used Redling CV grease for them. Its red and not real heavy like wheel bearing grease. Recommended by the dealer.
  5. Nov 21, 2014 at 2:13 AM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    I use staplex red grease
