What is a good price for a solid axle?
Discussion in 'Toyota Trucks & SUVs' started by luk8272, Jun 13, 2010.
  1. Jun 13, 2010 at 6:48 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Gone shopping for a solid axle to put on my 90 Toyota. I have a few prospects, all coming off of 81-85 4x4 toyota trucks. What would be a good price for one of these? One guy is asking $300, axle comes off of an 81 auto. I am not sure if it is on the truck or off. Another place says we can talk about the price depending on which one I choose, they have multiple.
  2. Jun 13, 2010 at 7:22 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Bump on price opinions
  3. Jun 14, 2010 at 4:29 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What axles are you looking at? Toyota axles?
    Have you searched for Grand Wagoneer Dana 44's?
    Most of the Solid Axle Swaps I've seen have used Jeep Grand Wagoneer Dana 44. The same axle I swapped under my jeep years ago.
    Mine was from an 89 Grand Wagoneer - drivers side drop, 60" wide, no vacuum disconnect.
    I bought a set of Dana 44's (front & rear) for $500. The front included all brake hardware & steering hardware.
  4. Jun 14, 2010 at 6:44 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    The only Dana 44 axles I have been able to find come off of Ford trucks/Broncos. I have access to 2 78 broncos sitting at my dads, both have Dana 44's. These are not leafed fronts. I have considereed these but ran across some stock toyota truck 4x4's. In which case I would only need to by a SAS kit and the front solid axle off of one of these trucks. The gears would match up with mine if I can find an auto donor.
    Thanks for the reply Janster.
  5. Jun 14, 2010 at 7:50 AM
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    They are usually listed for anywhere between 200-300 for a stock toy axle. Add gearing, lockers and brake upgrades and the price increases quickly. The early toy axle would be a great choice for your ride. you would need a set of 1.5" or so wheel spacers to get your front track width equal to the rear though.
  6. Jun 14, 2010 at 8:49 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Was looking to add this (Or similar) in conjunction with the 84-85 axle Standard Front Solid Axle Swap Kit: $1,399 PLEASE CALL TO ORDER
    Components:
    Quantity:
    Hy-Steer™ crossover steering featuring our exclusive one-piece forged arms
    1Weld on Shock Hoops with braces
    25100 Series Bilstein shocks
    24", 5" or 6" lift, long travel front leaf springs with bushings
    21" lift Spring hanger kit with greasable shackles and frame tubes and jigs
    1Vented Land Cruiser style rotors (Allows use of IFS brake calipers)
    21.5" Front wheel spacers
    2Front U-Bolt flip kit
    1Steel Braided DOT approved brake lines
    2Bumpstops 2Steering Stabilizer and brackets
    1Kit does not include driveshaft or axle.
  7. Aug 7, 2010 at 3:57 PM
    JudeLeBlanc
    JudeLeBlanc Active Member
    Baton Rouge, LA
    06 Single Cab PreRunner SR5
    Weather Techs
  8. Aug 7, 2010 at 7:27 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I hadn't even thought to update. I picked up and entire front end (hub to hub) off of an 81 Toyota truck. The new front axle has the same gears my existing rear has. I pressure washed it and set it to the side until my funds enable me to do what I need. Thanks for all the input.
