What is best way to remove rusted rear shock top nut?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KTM753, Jun 22, 2019.
  1. Jun 22, 2019 at 6:40 PM
    KTM753
    KTM753 [OP] Well-Known Member
    I cut the passenger side top nut off with a cutoff wheel but I still have the other side to remove. Been spraying the threads with PB Blaster but I can't get the nut to turn. Damn brine they spray in the winter here is awful on fasteners.
    I need another cutoff wheel because I went through my last one getting the passenger side off. Should I try a Bi-metal sawzall blade? Metal air saw blade?
    Any another tips to get the nut off?
  2. Jun 22, 2019 at 6:42 PM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Sawzall will work.
  3. Jun 22, 2019 at 7:56 PM
    vwbuggsy
    vwbuggsy Well-Known Member
    Clinton, MD
    09 DC 4X4 LB Black Sand Pearl
    N-fab steps, Wet Okole Covers, line-x, tint, vent shades, budget stereo upgrades, weathertech floor liners
    A 50/50 mix of acetone and atf. I find this works better than pb blaster for the really tough stuff.
    Do you have a torch? A good bit of heat then smack it with a hammer, then some good umph with a cheater pipe for extra leverage.
  4. Jun 22, 2019 at 8:03 PM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Burn it off with the O/P torch is generally my go-to. It doesn’t help that the threaded section is about 36 miles long...
  5. Jun 22, 2019 at 8:05 PM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  6. Jun 22, 2019 at 8:06 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Try heat red hot then spray it with water - worked for me with a lot of rusted bolts and nuts in the past.
    Sawzall was suggested - you might want to try a dremel with a cut off wheel - I've use the dremel many times for problems like this - not this particular problem but it would probably work.
  7. Jun 22, 2019 at 8:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    :sawzall:
    wilcam47 and whatstcp like this.
  8. Jun 22, 2019 at 8:14 PM
    FishingPups
    FishingPups Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    Heat it up and pour some of this on it. Let it sit overnight.
  9. Jun 22, 2019 at 11:50 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    29DB8D5A-60AD-436B-8FC3-7EA41D3FE797.jpg X2
  10. Jun 23, 2019 at 12:13 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Sawzall is how I get them off at work.
  11. Jun 23, 2019 at 3:06 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Cut it- PSA- wear safety glasses as it will pop straight up once the blade it through.
    Juforrest likes this.
  12. Jun 23, 2019 at 3:11 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You can use some brake fluid and a syringe. Use the syringe to put brake fluid into the threads.
  13. Jun 23, 2019 at 3:15 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    Pee On It! Could take more than one application!
  14. Jun 23, 2019 at 7:30 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Sawzall! There's too much pucker factor when throwing sparks near fuel tank with a cut-off wheel!
    crhsharks12 likes this.
  15. Jun 23, 2019 at 7:32 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Goaa be careful doing this, if you get the shock mount hot then cool it off like that it will weaken the metal
  16. Jun 23, 2019 at 7:41 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Assuming they're not going back on, sawzall, or visegrip the crap out of the shaft if you're skeered, it'll come loose or snap, either way you win! (Unless you bust your knuckles when it gives, I guess that would be a draw?)
  17. Jun 23, 2019 at 7:44 AM
    fb40dash5
    11 V6 AC 4x4
    Eh... they're so anal about vapor emissions they put a charcoal filter in the airbox... unless you opened something up, there's no more fuel vapors next to your fuel tank than there are anywhere else in the atmosphere. If you've got a sealed gas can in the garage, there's more vapor hanging out on account of that than your gas tank.
  18. Jun 23, 2019 at 7:56 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Still...I'm not gonna risk my shiny truck and this perty face when I could be using a better/safer approach.
  19. Jun 23, 2019 at 8:12 AM
    08RC
    08RC Well-Known Member
    Didn't think twice sawzall done in 60 seconds . Worrying about blowing up my truck is a nonissue . If fumes were escaping you would have a check engine light on with an evap code. Not to mention as a young fellow pumping gas at a garage with some real crazy's for years and not one incident in the 60s nore heard of one. My 2.0 Foxes will be coming off this week but I coated the threads with Synthetic disc brake lube so they will come off like I just installed them
  20. Jun 23, 2019 at 9:18 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
