What is biggest tire that you can put on a 2017 TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Badlandstags, Oct 19, 2016.
  1. May 26, 2017 at 1:15 PM
    #101
    jake slatnick
    jake slatnick Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    285/75!!
    solomoto79 likes this.
  2. Dec 8, 2017 at 9:43 PM
    #102
    solomoto79
    solomoto79 Member
    How?
  3. Dec 8, 2017 at 10:16 PM
    #103
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Easy. You buy the tires and have them mounted.
  4. Dec 9, 2017 at 6:28 AM
    #104
    Bt_osu
    Bt_osu Well-Known Member
    Sw
    2018 Black Trd Pro Automatic
    Trd cold air intake and oil and radiator caps. 2657516 bfg ko2s. Bak revolver 2 tonneau cover, bed mat and extender. Mud flaps. Husky liner floor mats. Locking tail gate. Led bed lights. Carbon black tailgate Tacoma insert. Red Tacoma dash insert. Winco Infrared reducing window tint. Predator steps.
    2657516 gives you a half inch taller sidewall or a 1 inch taller tire. It better fits the wheel well in my opinion and i wanted to go more aggressive than stock tire anyways. It also only effects your Speedo about 2 mph at highway speed. You'll be going 2 mph faster than the Speedo says. Not a big disparity. If you go bigger you'll have to cut and make alterations and the Speedo will be affected far greater
    aceiswar and jake slatnick like this.
  5. Dec 10, 2017 at 6:25 PM
    #105
    aceiswar
    aceiswar Well-Known Member
    absolutely not. there is rubbing.
  6. Dec 10, 2017 at 6:55 PM
    #106
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    It’s like we just go around in circles here. Look back through this thread (to help, here: https://www.tacomaworld.com/threads...on-a-2017-trd-pro.456522/page-4#post-14861587). Very minimal fender work with nothing other than a heat gun. No cutting required. Completely doable with VERY little modification.
    To be fair, I’m not running this tire yet but those that have are reporting similar results. I will be going with this tire once my stock ones are done.
