What is causing my Dakars to become misaligned ?
Discussion in 'Suspension' started by OZ-T, Aug 20, 2012.
  1. Aug 20, 2012 at 9:56 PM
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    I have also noticed a bit of axle wrap since I installed the axle shims too
  2. Aug 21, 2012 at 1:15 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    If you're up to it Oz , get that sucker in the air (with jack & stands, not go out & jump it..haha) remove the Ubolts, drop the axle far enough to seperate from springs (go a couple inches) get a couple good "C" clamps & clamp tight as hell on each side of centerpin, get vice grips & grip the hell out of the bottom of centerpin to hold it still because you're going to re tighten the pin, those shims are thin & give some under tightening sequence , sometimes this gives a false sense of torque (feels tighter than its actually getting) after re torquing I'd run another nut behind it & snug it tight, re assemble , see if this stops your leafs side to side" movement
  3. Aug 21, 2012 at 8:40 AM
    OZ-T
    Peter North
    British Columbia
    Thanks Doug
    Just about to get under there and check it out , but I was thinking about it last night and basically came to the same conclusion as you just posted . My axle shims are the old style that Toytec used to sell that are slotted instead of tight to the centre pin like the new ones .
    The job I am working right now has me up and down an unfinished fire road that has gotten pretty bad in some spots which is putting some flex and a lot of bounce / rattle through the truck .
    I wondered if maybe the shim on that side had just backed up a little relative to the axle , thus allowing some slack .
    I will have both packs out to install new shackles and the OME AAL soon , I will add the second nut as you suggest at that point .
    Thanks for the responses gentlemen
  4. Aug 21, 2012 at 10:11 AM
    OZ-T
    Peter North
    British Columbia
    I believe I will
  5. Aug 21, 2012 at 11:17 AM
    OZ-T
    Peter North
    British Columbia
    So , as it turns out the U bolt torque was the culprit .
    The driver's side , which was the problem side , had 3 of the 4 below the 90 ftlbs , we set them to when installing the axle shims , one nut was really loose .
    I loosened them all slightly , realigned the leafs as best I could , and re-torqued them , this time to 100 ftlbs
    The passenger side bolts were under 90 ftlbs as well , but for some reason this leaf pack had no side to side movement , I did the same routine to this side , loosen slightly and re-torque to 100 ftlbd .
    The noise seems to be gone aside from one slight click / clunk that I attributed to the driver's side leafs just moving slightly back to their neutral position after my manipulation of them .
    Thanks for all the responses .
  6. Aug 21, 2012 at 5:24 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I'd run your road a couple more times and re-torque em.
  7. Aug 21, 2012 at 5:36 PM
    OZ-T
    Peter North
    British Columbia
    Will do
  8. Aug 21, 2012 at 5:45 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    So this is the mysterious notorious clunk?
    Glad you left me hanging yesterday :(
  9. Aug 21, 2012 at 5:59 PM
    OZ-T
    Peter North
    British Columbia
    You didn't answer me when I said I was going to light my truck on fire so I took matters into my own hands with a little help from these good peeps
  10. Aug 21, 2012 at 6:00 PM
    XXXX
    sKiP
    05 Prius
    whatever..... I was busy and said call me
    keep crying wolf and one day no one will answer your calls for help :D
  11. Aug 21, 2012 at 6:04 PM
    OZ-T
    Peter North
    British Columbia
    Peter and the Wolf ?
  12. Aug 22, 2012 at 6:12 PM
    OZ-T
    Peter North
    British Columbia
    OK , so the fucking clunk is back , checked the U bolt torque and it was still fine
    Checked for broken leafs
    No rocks caught between the leafs
    Next ?
  13. Aug 22, 2012 at 6:13 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    is it possibly your shocks?
  14. Aug 22, 2012 at 6:15 PM
    OZ-T
    Peter North
    British Columbia
    Pretty sure it's the leafs , I can almost feel a bind and release when the clunk happens
    It occurs when the truck is turning with some flex , loading that side of the rear
    My other thought was it could be that the front leafpack bushing is dried out or seized
  15. Aug 22, 2012 at 6:21 PM
    #35
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    it doesnt do it on bumps?hows the leaf spring bushings and torque on the bolts
  16. Aug 22, 2012 at 6:21 PM
    #36
    Cogge89
    Cogge89 Well-Known Member
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    Pioneer AVH-P4100DVD, Kicker ZX400.1 Amp, Kicker CVT 10" Sub. Light Racing UCAs, Front OME Shocks with 885x Coils, Rear OME Shocks with Dakar Leaf Pack, Engine Cover Paint Job, 265/70/17 Duratracs.
    I've been noticing a clunking during flex too. I keep nothing in the bed. I actually thought I ripped my brake line out at first. I may have to check my leafs tomorrow or maybe I'll just check out the f150 eco boost I've had my eye on :cool:
  17. Aug 22, 2012 at 6:23 PM
    #37
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    take some 3/4" flat bar stock maybe 1/8" or 1/4" thick and 4 strips for each side. Measure the thickness of your leaf pack then add an inch or so for a bolt top and bottom. Basically you are making a clamp to hold the together. I had the same problem with mine except I have stock leaf packs. Made the clamps and put them on and they have not moved since.
  18. Aug 22, 2012 at 6:27 PM
    #38
    Commie
    Commie Well-Known Member
    G
    Hanford, CA
    TRD Off-Road
    SCS F-5 Black with BFG AT 265/75/16, 2.0 Radfls's w/ top plate, LR UCAs, TSB springs w/ 5160, rear diff breather, blacked out grill/ emblems/ rear bumper/ lower valance, LED map/ dome/ lic plate lights, switchback DTRLs, anytime fogs, WeatherTech DigitalFit liners
    How do you take apart the rear end? Do you jack up the entire truck and drop the whole rear axle or do you just jack up one side at a time and do it that way? If youre doing just one side at a time you might not be getting everything to sit right especially with the axle shims since they angle the rear diff. Try dropping the entire back end and tigten everything the same amount of turns. Also if its a really loud clunk and happens when you are flexed maybe it is you shocks extending out all the way and they could be too short for the amount of lift that your springs give you
  19. Aug 22, 2012 at 6:28 PM
    #39
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    as stupid as this sounds, whats the condition of the rubber pads on the upper shock mount? and how are the bushings on the bottom?
  20. Aug 22, 2012 at 6:29 PM
    #40
    Konaborne
    Cody
    Kealakekua, Hawaii
    some of my clunks come from my silencers/rubber pads that stick the leafs together coming unbound on big turns or when I flex it out
    though idk how the dakars are
