What is causing my Dakars to become misaligned ?
Discussion in 'Suspension' started by OZ-T, Aug 20, 2012.
  1. Aug 22, 2012 at 6:40 PM
    #41
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    There is 3 clamps per pack on the Dakars
  2. Aug 22, 2012 at 6:41 PM
    #42
    OZ-T
    Peter North
    British Columbia
    I'll check that too
  3. Aug 22, 2012 at 6:43 PM
    #43
    OZ-T
    Peter North
    British Columbia
    Not at anywhere close to full flex , and I have the OME N182 shocks designed to go with the Dakars
  4. Aug 22, 2012 at 6:51 PM
    #44
    OZ-T
    Peter North
    British Columbia
    Monkey ,
    The top shock bushing rubbers look good , no tears , not squished out , not sure how I would know about the bottom without removing the shock
  5. Aug 22, 2012 at 7:20 PM
    #45
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    are they bending and seperating? thats what happened to the ones on my stockers
  6. Aug 22, 2012 at 7:22 PM
    #46
    OZ-T
    Peter North
    British Columbia
    Nope
    A couple seemed rotated a bit , but I straightened them out
  7. Aug 22, 2012 at 7:29 PM
    #47
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I only mentioned the bushings because mine were completely shot on the bottom and had quite bit of play. I hadn't ever noticed that play in the bushings before because everytime I check over the truck I always have it up in the air. The droop against the shock had the right amount of pressure on it to make it seem like everything was good.
  8. Aug 23, 2012 at 10:36 AM
    #48
    OZ-T
    Peter North
    British Columbia
    I'm going to check the torque values on the shackles and front mounts .
    Heard a couple clunks this morning , same thing , turning while slightly flexed , loading the driver's side .
    Is it possible for the mounting bolts to be seized in the bushing sleeves similar to what occurs to the LCA bolts ?
    How can I tell if the shackle mount is bent ? On a level surface should it be absolutely plumb relative to the frame ?
  9. Aug 23, 2012 at 11:07 AM
    #49
    MonkeyProof
    SoCal- SGV
    My rear shackle mounts look like this. // \\ :cookiemonster:
  10. Aug 23, 2012 at 11:25 AM
    #50
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    leaf spring mis-alignment is commonly caused by a loose centering bolt.
    Replace that with a grade 8 cap bolt... red loctite that...
    and torque the hell outta it.
    Dakars suck IMO... as they only have three u brackets to help keep the individual leafs in alignment.
    tho' "U" bolts can become loose and be blamed.
    they do little to maintain alignment of the leafs in a spring pak.
    A thunk or clunk at the rear, during acceleration or braking
    is commonly associated with axle wrap...
    and the driveshaft's "slip shaft" lacking lubrication...
    grease that... and see if it goes away or is minimized.
  11. Aug 23, 2012 at 12:08 PM
    #51
    OZ-T
    Peter North
    British Columbia
    My driver's side one looks a bit //
  12. Aug 23, 2012 at 12:24 PM
    #52
    OZ-T
    Peter North
    British Columbia
    Thanks for your reply
    I will be replacing / retorquing the centre bolts soon .
    How many U brackets do you think would be appropriate for the leaf packs ?
    The clunk doesn't occur during accel or braking and I'm quite certain is not axle wrap related .
  13. Aug 23, 2012 at 12:40 PM
    #53
    MonkeyProof
    SoCal- SGV
    Have you torqued the bed bolts. Mine come loose all the time even with the addition of red locktite. I know when they are loose because I will hear a clunk noise, especially the closest one up front closest to the cab. Sometimes they can work themselves loose enough that you can grab the corner of the bed and actually lift it up some.
  14. Aug 23, 2012 at 12:41 PM
    #54
    OZ-T
    Peter North
    British Columbia
    I'll add that to the list of things to check
    Thanks
  15. Aug 23, 2012 at 12:45 PM
    #55
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    I had a similar problem with my leafs becoming mis-aligned. I had to over-torque them to get them to stay in place. (Not dakars, just an AAL)
  16. Aug 23, 2012 at 2:24 PM
    #56
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
  17. Aug 23, 2012 at 8:44 PM
    #57
    OZ-T
    Peter North
    British Columbia
    My Dakars already have 4 clamps per side and they are already limiting the side to side action
    I checked the front bushing and shackle bolts , they check out for torque and don't seem seized in the bushings
    I have to get the pack out as a few of you suggested and check the centre pin bolt
  18. Aug 23, 2012 at 8:59 PM
    #58
    OZ-T
    Peter North
    British Columbia
    FYI , my 2nd gen ones have 4 , 2 forward of the U bolts and 2 rear
  19. Aug 23, 2012 at 10:30 PM
    #59
    OZ-T
    Peter North
    British Columbia
    What are the chances of the centre pin being broken ?
  20. Aug 23, 2012 at 10:30 PM
    #60
    OZ-T
    Peter North
    British Columbia
    That's a question not an observation ^^
