What is causing this!!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcgem22, May 28, 2023.
  1. May 28, 2023 at 8:17 AM
    bcgem22
    bcgem22 [OP] Member
    Ben
    2008 Black Tacoma 4x4 ex cab
    2008 Tacoma automatic 4 x 4 has been making the “ac expansion valve whistle” sound on and off lately. (It sounds identical to
    The videos I’ve watched, but can’t be 100% sure)
    It will increase in pitch with acceleration but does go away quickly. Comes back here and there while driving. NO AC is being used while this is happening.
    No sound at all on highway, going 75-80. Sound returned as I came to a stop after getting off an exit.
    No sound at all today in rain driving around town.
    This is baffling me. I took it to
    Toyota and they replaced my ac clutch and it did nothing. I’ve read this could be just a common quirk- but I must stress it happens when the AC is off!!
  2. May 28, 2023 at 8:47 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't see how it is making an "ac expansion valve whistle" when it isn't running the A/C. I would be more inclined to believe that the duct work has a damaged foam seal that is whistling. Esp on a 2008 model (15 years old ).
    Does it do it with the fan OFF?
    Ridgewalker1 likes this.
  3. May 28, 2023 at 8:52 AM
    bcgem22
    bcgem22 [OP] Member
    Ben
    Yes. The Reason I referred to the expansion valve whistle, is because that is exactly what it sounds like.
    The dealer specked it it was the AC, but the AC was working perfectly the whole time without any issue. So for the sound to be happening when the AC is off, fan is off, I’m really stumped
  4. May 28, 2023 at 8:54 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Is the A/C off or are the controls set in the defrost mode which can cycle the A/C even if the A/C isn't ''on?''
    Waasheem and Jimmyh like this.
