what is clutch fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woodchip, Jul 13, 2016.
  1. Jul 16, 2016 at 9:04 AM
    Pigpen
    Dan
    Northwest Montana
    This is why I love TW -I learn stuff.
    Now we need a clutch bleed write up
  2. Jul 16, 2016 at 2:20 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Agreed on model-specific but, since my TRD OR (with Tow Package) has separate reservoirs and your SR5 doesn't, it must be part of the OR and/or Tow packages. I don't recall it listed in any of the documentation, though... :confused:
    I just did mine last weekend, but didn't think to take photos. Pretty simple process, though it requires two people (one to pump the pedal and one to open the bleeder). Note that, if you have separate reservoirs, the clutch one is TINY. I had to refill after opening the bleeder valve only ~5 times. In light of that, I figure 7-8 openings constitutes a full flush of the system.
  3. Jul 16, 2016 at 2:25 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I believe its related to the type of master cylinder and booster you have. Traditional style vacuum booster and MC then its shared reservoir. If you have that electro-hydraulic unit then its separate reservoirs, something to do with ATrac or VSC.
    Norton and DaveInDenver like this.
  4. Jul 16, 2016 at 2:35 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I think we may have figured it out. I have the tow package on my SR5. It has a vacuum booster so it must be TRD OR trucks have a separate reservoir...
  5. Jul 16, 2016 at 2:36 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I have 2008 TRD Off Road with tow package with vacuum booster and shared reservoir. It depends only on A-TRAC and VSC, which I do not have. Now what years those came with what packages, I don't know.
    shakerhood and Norton like this.
  6. Jul 16, 2016 at 2:52 PM
    Norton
    +1.
    Thanks for the education, @shakerhood and @DaveInDenver!
    shakerhood and DaveInDenver like this.
  7. Jul 16, 2016 at 5:35 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    09+ trd or 4x4 came with a-trac
    DaveInDenver[QUOTED] likes this.
  8. Jan 24, 2018 at 8:06 AM
    WPNZ
    WPNZ Well-Known Member
    Tucson Arizona
    14 DCSB SR5 6MT
    Yes thanks for this info, was trying to figure out what could have been bolted to my inner fender.
