What is coil bind?
Discussion in 'Suspension' started by Nvhntr, Dec 13, 2018.
  1. Dec 13, 2018 at 11:56 AM
    Nvhntr
    Nvhntr [OP] Member
    2016 Tacoma TRD Off Road
    as the title states im curious what people are referring to when they talk about coil bind and what causes it. Thanks for your response
  2. Dec 14, 2018 at 2:46 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Coil Bind is when the coil cannot compress anymore and is pretty much in its complete compressed length. Sometimes depending on the scenario with springs and shock and how much preload. I have come close to coilbind on some trucks. Its the danger when your coil compresses before your shock can fully compress and all the bottoming load goes on the shock and its mounting points.
  3. Dec 14, 2018 at 2:50 PM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    It's when the coil binds....
    :anonymous:
    koditten likes this.
  4. Dec 15, 2018 at 4:05 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Does this cause a popping noise? I’ve had a pop from the front when going over humps or taking sharp curves and the suspension compresses. Almost sounds like a sway bar bushing pop but I no longer have a sway bar so can’t be that.
  5. Dec 15, 2018 at 4:12 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Check to make sure you do not have a broke spring. I had to pull the wheel to see the broken front spring.
  6. Dec 15, 2018 at 4:19 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    No broken springs. They are old oem springs on bilstein 5100s though. I have a set of OME 883s I’m going to swap on once this rain clears out. Hopefully that will fix this pop. I’ve already replaced lower control arm bushings, put spc upper control arms on, and replaced lower ball joints with oem.
  7. Dec 15, 2018 at 10:25 AM
    Anthony250
    Anthony
    Rialto CA
    Not really, has to be someotherthing
  8. Dec 15, 2018 at 11:09 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    Yea that’s why I thought maybe coil binding. Guess the search continues.
  9. Dec 17, 2018 at 10:28 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Your issue may be the tire hitting the upper control arm. Dose it do it with the wheels straight and turned? Look for witness marks on the upper control arm and the tire. Also check the bump stop.
  10. Dec 17, 2018 at 12:09 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    No contact on upper control arms. I did have contact on knuckle to coil but I have SPC control arms now so no problem there anywhere.
