What is considered HIGH Mileage for these 1st Gens?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoreysIRTaco, Apr 4, 2019.
  1. Apr 5, 2019 at 6:22 AM
    #41
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Im the original owner so maybe
    GQ7227[QUOTED] and 1997tacomav6 like this.
  2. Apr 5, 2019 at 6:23 AM
    #42
    GQ7227
    GQ7227 mw survivor
    J A Y
    what's your current mileage?
  3. Apr 5, 2019 at 6:23 AM
    #43
    Wixo
    Hank
    Tint, LED interior
    One of the guys at the shop once told me "yeah this is. great truck, itll even last you 7 years if you take care of it" Yeah right boi more like 20 years
    GQ7227 likes this.
  4. Apr 5, 2019 at 6:24 AM
    #44
    Wixo
    Hank
    Tint, LED interior
    I just hit 66K some time this week so Im anywhere between 66200-66300
    GQ7227[QUOTED] likes this.
  5. Apr 5, 2019 at 6:26 AM
    #45
    GQ7227
    GQ7227 mw survivor
    J A Y
    those guys that live in Hawaii gotta drive around the island alot to make 1million lol
    what month? mine was in early May
  6. Apr 5, 2019 at 8:32 PM
    #46
    sramirez1516
    sramirez1516 Saul R.
    Saul
    2002 Toyota tacoma xtracab prerunner 2.7
    None
  7. Apr 5, 2019 at 9:36 PM
    #47
    dweikum
    dweikum Well-Known Member
    Duane
    Oakland CA
    02 4WD V6 5spd SR5 TURD
    I recently bought mine at 220K figuring it should have plenty of life left in it, even after the PO abused the hell out of it.
    CoreysIRTaco[OP] and GQ7227 like this.
  8. Apr 6, 2019 at 4:21 AM
    #48
    pcm
    pcm Well-Known Member
    I have 312,000 on my '02. It runs like a champ. It has the 2.7L V4. Gas mileage is still pretty good. Have had a lot of work done...new frame (manufacturer recall) and replaced much of the rusted out parts while it was torn down, bit the engine is all original. Regular maintenance is done and oil change every 3,000.
  9. Apr 6, 2019 at 4:41 AM
    #49
    GQ7227
    GQ7227 mw survivor
    J A Y
    hopefully your engine while running don't sound near anything like the 'o3 I just inspected here they are trying to move for $11k with half the miles you have and 5 prior owners
  10. Apr 6, 2019 at 4:58 AM
    #50
    dweikum
    Duane
    Oakland CA
    My V6 runs like a top! 5spd could do with a little TLC though. Have never rebuilt one before...how hard could it be?
  11. Apr 6, 2019 at 5:00 AM
    #51
    GQ7227
    GQ7227 mw survivor
    J A Y
    great! I am curious too how much it actually is to totally rebuild the 3.4 having an independent certified Toyota mechanic to do it
    if anybody does pay $11k for that one I mentioned it will probably easily become a $15k truck to get it working like I think it should
  12. Apr 6, 2019 at 5:14 AM
    #52
    dweikum
    Duane
    Oakland CA
    Well, I just watched almost half a video on how to rebuild the trans and I can safely say, I'm out, above my pay grade...dammit.
  13. Apr 6, 2019 at 5:20 AM
    #53
    1997tacomav6
    Denver
    You can get a good used one all day long in the 3-500 range depending on miles.
    Look at carparts
    http://www.car-part.com/mobile//index.htm
  14. Apr 6, 2019 at 5:33 AM
    #54
    dweikum
    Duane
    Oakland CA
    Maybe in Denver...Bay area, not so much. Thanks for the link though!
  15. Apr 6, 2019 at 12:10 PM
    #55
    robman3
    robman3 Member
    1997 3.4l TRD
    305K miles on a '97. Normal maintenance items belts, plugs, fluids, filters, brake pads, batteries, vacuum valves, light bulbs, timing belt w/water pump kit. Alternator, rotors & calipers, wheel bearings & seals, rear shocks, front bushings, valve cover gaskets. Still has original exhaust components. Never leaks oil from transmission, engine sump, transfer case, differentials. (PS I copy pasta'd most of this post...)
    GQ7227 likes this.
  16. Apr 6, 2019 at 12:21 PM
    #56
    GQ7227
    GQ7227 mw survivor
    J A Y
    original radiator still?
  17. Apr 11, 2019 at 9:38 AM
    #57
    robman3
    robman3 Member
    1997 3.4l TRD
    @GQ7227 I just replaced the OG radiator a few weeks ago, the hood finally caught and smashed the OEM.
    GQ7227 likes this.
  18. Apr 11, 2019 at 11:08 AM
    #58
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    0w-40
    cruiserguy likes this.
  19. Apr 11, 2019 at 11:15 AM
    #59
    Wulf
    Wulf no brain just damage
    rock raisin
    420k
  20. Apr 11, 2019 at 11:16 AM
    #60
    Wulf
    rock raisin
    Rosella T time
