what is ect snow and when should i use it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Dec 22, 2009.
  1. Dec 22, 2009 at 8:12 AM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
  2. Dec 22, 2009 at 8:13 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    ect is electronic controlled transmission or something like that
    you push the button and it changes your shift points to aid in towing
  3. Dec 22, 2009 at 8:17 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    basically holds the gear longer raising rpm's to aid in towing like Tiger said
  4. Dec 22, 2009 at 8:24 AM
    DaytonLax14
    Corey
    Ohio
    so it has nothing to do with snow?
  5. Dec 22, 2009 at 8:26 AM
    JimBeam
    JB
    2015 Tundra
    absolutely nothing...why?
    i was wondering why snow was in the title
  6. Dec 22, 2009 at 9:24 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Its the same thing as overdrive isnt it?:confused:
  7. Dec 22, 2009 at 9:37 AM
    JimBeam
    JB
    2015 Tundra
    no
    i also have a button to turn o/d off
    im not sure of the difference between the 2 but i have both...soo...i dont think theyre the same
  8. Dec 22, 2009 at 9:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    O/D is actually for towing
    ECT is to give the truck a more "sporty" feel.
  9. Dec 22, 2009 at 9:58 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I'm guessing no owners manual?
  10. Dec 22, 2009 at 10:14 AM
    DaytonLax14
    Corey
    Ohio
    correct you are
  11. Dec 22, 2009 at 10:35 AM
    Justin723
    Justin723 Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    In the Normal mode you get better efficency and greater mileage. In the Power Mode the transmission shift points are changed to allow for more power IE twoing, and great for down shifting
  12. Dec 22, 2009 at 3:43 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    Where does it say "snow"...? The ECT POWER button is for towing, hauling heavy loads, driving up long hills, etc. It let's the engine RPMs rev higher before the tranny shifts into the next higher gear like mentioned above. It helps you get up to speed quicker. The O/D button on the stick is for Over Drive gear. This allows the truck to get into Over Drive, which in all reality is like a 4th gear, or cruising gear. This was designed to keep your cuising speed RPMs lower to save gas, thus better gas mileage.
  13. Dec 22, 2009 at 6:15 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    i have the same feature in my truck and have never used it - but then i dont tow anything.
    from my understanding the ECT works best if you are towing over hills or long inclines. the ECT works in conjunction with the O/D button on the shifter to prevent the transmission from jumping into overdrive. if you have ECT on and O/D on then you basically have a fourth gear to work with. if ECT is on and O/D is off your truck will not be able to automatically jump into overdrive.
    because it changes when the transmission will shift into overdrive, if you are not towing anything having the ECT on will only eat up more gas.
