What is everyone have their Icon coilovers set on as far as thread showing measurements?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OddTaco, Dec 1, 2015.
  1. Dec 2, 2015 at 3:15 PM
    OddTaco
    OddTaco [OP] Member
    2016 TRD OFF-ROAD
    Thanks Wiley for the info I will be ordering some new spring next week to sort out the problem. I really appreciate hearing from you guys that are educated with the next level lift info!
  2. Dec 2, 2015 at 3:19 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i have a little over 2" on my icons. I want to swap to 14" 700# coils upon my rebuilt to possibly have a little less preload. Mine rides great, in fact i feel it rides a little stiffer with less pre-load. My angles are still great.
  3. Dec 2, 2015 at 3:52 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I'm sorry man. I didn't mean to come off that way.
    I hope you get your lift sorted out.
  4. Dec 2, 2015 at 4:15 PM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    are you planning on having an additional weight in the front end? theres different spring options you can go with. Eibach makes a 14" 650lb coil if you dont want to be too stiff in the front.
  5. Dec 2, 2015 at 5:24 PM
    OddTaco
    OddTaco [OP] Member
    2016 TRD OFF-ROAD
    Not yet on the additional weight but I plan on getting some armor up front so I will probably wait on the springs until then so it's all finalized at one time. Thanks again for the info!
  6. Nov 24, 2017 at 1:23 PM
    BlackTacosMatter92
    BlackTacosMatter92 Well-Known Member
    Jay
    2017 DCLB Tacoma
    King Suspension SPC UCA's Dakar Medium Leaf Packs Nitto Ridge Grapplers 255/75/16 VTX Vipers 16x8 (-12) Mobtown CMC plates Mobtown Sliders Smittybilt X20 10k Synthetic Factor 55 Fairlead & Flatlink MBRP Off Camber Fabrications Front Bumper MBRP Black PowderCoat Exhaust RX350 Projectors TRD Pro tail lights Truxedo Lo Pro QT Tonneau RCI Bed Rack Total Chaos Bed Stiffeners ARB CKMA12 CustomCarGrills Grille Line-X'd Grille 20% Window Tint (Front/Back) 75% Windshield 5% Visor Debadged
    Haha I know this is a little old, but was going from 13" 600lb to a 14" 700lb too much? I'm about to buy an ADS suspension and swap for a 14" coil right away but not sure if I want 650 or 700lb
  7. Aug 12, 2019 at 8:00 AM
    S550ilver
    S550ilver Well-Known Member
    Bartlett, TN
    2019 Tacoma Double Cab TRD Off-Road
    ICON Stage 5 Lift, 18x9 Fuel Shok, Nitto Ridge Grappler 285/65/18 tires
    My Stage 5 ICON lift on my 19 Tacoma Off-Road is about 2". On the instructions it says not to go past 2.13" for 16-up Tacomas. When my installer originally did them, I had maybe 1.5" or a bit less of threads showing, resulting in a slight rub from my 285/65/18 Ridge Grapplers when i would turn the wheel at a certain point and it was raked so it was a bit lower in the front (a good bit when you looked at it from the side). Took it back and got the threads showing to about 2". No rubbing now. Ride is just fine. Looks way more level now.
