What is going on here?
Discussion in '1st Gen. Tacomas (1995-2004)' started by takern, Jan 10, 2014.
  1. Jan 10, 2014 at 7:26 AM
    takern
    takern [OP] Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    I replaced my outer tie rod a little while ago because it was shot. Today I crawled under to take a look at the rack bushings because my steering has got really loose lately, and I saw this on the ball joint I replaced. I added a picture of the passenger side, which looks normal as a reference. Is the joint not pressed in there right? Ive gone nearly 1500 miles since replacing it.
  2. Jan 10, 2014 at 7:33 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I'm no expert but it looks as if the castle nut holding the ball joint on has no pin in it and is backing out.
  3. Jan 10, 2014 at 7:38 AM
    takern
    Tanner
    Virginia
    just went and checked. the nut is seated and has the pin. maybe its the wrong joint and the bolt is too long?
  4. Jan 10, 2014 at 7:41 AM
    deeezy
    Dana
    Hawaii
    From looking at the pictures, it looked like there are more threads showing on the "good" ball joint.
  5. Jan 10, 2014 at 7:45 AM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    No matter what or how this happened, you will have to replace that outer left BJ. It is shot. And don't wait, or you may be in a ditch.
  6. Jan 10, 2014 at 7:46 AM
    takern
    Tanner
    Virginia
    damn alright. time to hit up the napa and see what I can do
  7. Jan 10, 2014 at 7:52 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    Make sure you have the truck back on the ground before you torque everything up.
  8. Jan 10, 2014 at 10:23 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  9. Jan 10, 2014 at 10:39 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Just wanted to point out that the picture is not of the lower balljoint. That joint in the picture is the outer tierod end. It also appears as though the outer tierod end on the other side is much newer than this one.
  10. Jan 10, 2014 at 10:47 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Its completely different too, the boots are different and the passenger side has a ring retaining the boot at the bottom. OP ,are you sure you you didn't replace the passenger side tie rod end?
  11. Jan 10, 2014 at 11:02 AM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    Can you wiggle it? Sometimes the bolt doesn't get seated all the way, and driving wiggled it to looseness. If you can wiggle it then you can try and tighten it, if you can't tighten it, I would park it dude.
  12. Jan 10, 2014 at 11:24 AM
    takern
    Tanner
    Virginia
    I just went ahead and replaced it. Got a lifetime warranty one from auto zone so if it happens again ill get a free one just like the cv axles. The castle nit was finger lose but the pin was still in so I'm thinkin it wasn't tightened down correctly the first time
  13. Jan 10, 2014 at 12:47 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Heads up for next time always replace parts in 2's especially ball joints. Better to spend and extra hour than end up in a ditch..or worse
  14. Jan 10, 2014 at 12:56 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    was it bent? Are the tie rods bent?
  15. Jan 10, 2014 at 1:21 PM
    takern
    Tanner
    Virginia
    Both ends were replaced less than 2500 miles ago. Didn't look bent or anything. Maybe just a defective end or it popped out while wheeling. No tellin
  16. Jan 10, 2014 at 1:23 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Lifetime warranty from autozone= face palm
  17. Jan 10, 2014 at 1:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Those two rod end do not look like they were replace at the same time. One looks much newer than the other, Also, one has a grease nipple, the other does not. To me this indicates they are different models/brands. Certainly not pairs.
  18. Jan 10, 2014 at 2:58 PM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    There is lots of confusion in this thread.
    for folks that dont know the difference between balljoints and tie rod ends, please dont post.
    OP:
    - always replace things like BJs and tie rod ends in pairs.
    - NEVER buy suspension components or critical items from Autozone.
    - when you get balljoints, make sure you spring for OEM Toyota. Camelback Toyota can get you hooked up for about $175 shipped for the pair.
    - lastly, use a torque wrench to verify the torque setting for your castle nut and your BJ mounting bolts.
  19. Jan 10, 2014 at 3:07 PM
    lipster
    Northern MN
    License plate frame
    I meant tie rod end, not BJ.
    Same message, replace, which he did.
  20. Jan 10, 2014 at 3:11 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Dafuq? If it aint broke dont fix it.
    I have numbered your post.
    Can you please explain how you got to the logical conclusions for 1-3? Not even going to dable with number 4
    As for OP, pics show a possibility of not seating the ball joint within the spindle which would explain the finger tight issue you had when replacing it. With that being said you probably could have seated it and been good to go till it actually failed. Either way new tie rods for the win.
