What is going on here?
Discussion in '1st Gen. Tacomas (1995-2004)' started by takern, Jan 10, 2014.
  1. Jan 10, 2014 at 3:58 PM
    takern
    takern [OP] Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    They were replaced the same day. I was in a hurry and the auto parts store had two different brands, hence the different boots and one with a grease nipple, one without. Also accounts for the difference in rust protection they provided. Now both are enclosed/non-greasable
  2. Jan 10, 2014 at 5:25 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    If it aint broke dont fix it is a stupid mentality to live by.. If you only change one that has say failed at x number of miles what's to say that the next wont fail too plus it stops mix matched parts and having to have the truck back on blocks a few weeks later..
  3. Jan 10, 2014 at 6:22 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    So you're saying that I should have replaced my driverside rack boot because the passenger side was torn? Nothing is to say it isn going to fail, but if that bj was not showing any signs of fatigue he didn need to replace it.
    Lets play ur scenario, lets say cylinder 4 is shot on my truck. Does this mean I should replace all 4?
  4. Jan 10, 2014 at 6:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Lets pick any wear item where there is more than one. Would you only change one spark plug? One tire? One brake shoe?
  5. Jan 10, 2014 at 6:35 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    No try and fix cylinder 4,
    I don't want to start a argument....
    All I'm saying is that if you have one ball joint with 120,000 miles on it and you are under there replacing one side do them both that way they are both at 0 miles. Imo that the best way to do preventative maintenance so shit doesn't go down when your in the Bush or on a long haul.
  6. Jan 10, 2014 at 6:59 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    He said both were replaced 2500 miles ago. Are you guys suggesting he buys 2 again? I understand the 100,000 mile argument, but he just said they were BOTH replaced 2500 miles ago
  7. Jan 10, 2014 at 7:02 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I suggested replace neither. This guy is though
  8. Jan 10, 2014 at 7:15 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    I was stating replace both at the same time next go around...
    That was before the op said that they were both replaced at the same time but with 2 different manufacturers parts. And that's where people including myself are getting confused.
    In this situation sense the op has a brand new part on the passenger side I would just replace the drivers.
  9. Jan 10, 2014 at 7:18 PM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Like I said, if it had no significant damage I'd still sinch it back up
  10. Jan 11, 2014 at 5:30 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    Were you high when you wrote your response or just had not bothered to read the thread - which at the time was one whole page long?
