What is hubcentric?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Slick8810, Apr 30, 2009.
  1. Apr 25, 2010 at 2:20 PM
    #41
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    they are
    :thumbsup:
  2. Apr 25, 2010 at 2:20 PM
    #42
    shift96
    shift96 Well-Known Member
    Not true. Lug centric wheels have tapered lug nuts and Hub centric have straight lug nuts. Tacoma's have Hub centric Aluminum wheels.
  3. Apr 25, 2010 at 2:20 PM
    #43
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I never liked you anyway! :(
    How do you know your not?
  4. Apr 25, 2010 at 2:21 PM
    #44
    shift96
    No they are not, They are Hub centric. Really, check your info before you post false info. Just sayin
  5. Apr 25, 2010 at 2:22 PM
    #45
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    DAMMIT!!! Can someone clarify as to weather or not the First genners are Lugcentric???? I used Lugcentric nutts on mine.
  6. Apr 25, 2010 at 2:24 PM
    #46
    shift96
    It's very simple. If your lug nuts are TAPERED they are lug centric. If they are STRAIGHT SHANK then they are hub centric. Just picture it, how can the wheel be centered from the lugs if the are not tapered lug nuts????
  7. Apr 25, 2010 at 2:25 PM
    #47
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My first genner had tapered lugs.
  8. Apr 25, 2010 at 2:28 PM
    #48
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    really?
    false info?
    im with chris... my stock lugs were tapered... every set of wheels i have run on my truck has been tapered...
    every 1st gen truck we have built at the shop was lug centric...
    just recently someone on TW mounted hub centric wheels on a first gen and ran into issues and had to return the wheels...
    JUST SAYIN
    hahahahaha
  9. Apr 25, 2010 at 2:30 PM
    #49
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    WHEW! I had my first gen wheels off so many times, I cant count. I figured the second gens were the same.
  10. Apr 25, 2010 at 2:39 PM
    #50
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    in fact, i went to pick up spare lug nuts and according to the parts number book, it listed 12mm x1.25 tapered lug nuts
  11. Apr 25, 2010 at 3:02 PM
    #51
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    ya know, just when I think you couldn't be any dumber...you go and do something like this....AND TOTALLY REDEEM YOURSELF!!!! :laugh:
    quoted from the movie dumb and dumber
  12. Apr 25, 2010 at 3:03 PM
    #52
    ColtsTRD
    Scott
    AZ
    get in here for a hug big guy
  13. Apr 25, 2010 at 3:07 PM
    #53
    ColtsTRD
    Scott
    AZ
    Jamie lol
  14. Apr 25, 2010 at 5:12 PM
    #54
    shift96
    Don't know what Tacomas you are running but stock 1st Gen Tacoma's are ALL Hub centric there Jocko
    AND, I'm talking about Aluminum wheels. The steelies may be lug Centric
  15. Apr 25, 2010 at 8:02 PM
    #55
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    i give up... you are the expert here...
    :cheers:
  16. Apr 25, 2010 at 8:25 PM
    #56
    shift96
    It's all true info I state. Sorry
  17. Apr 25, 2010 at 11:23 PM
    #57
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Kinda glad to see I'm not the only one here that's confusilated! :notsure:
  18. Apr 25, 2010 at 11:51 PM
    #58
    ColtsTRD
    Scott
    AZ
    Confused????...Shit, I don't even know where I am :notsure:
  19. Apr 26, 2010 at 12:57 AM
    #59
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    My OE Aluminium Tacoma wheels were hub centric.
    They used standard Toyota mag lug nuts (Like these).
    After I removed the lug nuts the front wheels were still bonded / frozen to the truck by the tight Hubcentric fit. I then had to thread back on a few lugs and kick the wheels to dislodge them before removal.
  20. Apr 26, 2010 at 6:11 AM
    #60
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    A lot of the confusion has to do with the fact that wheels (in and of themselves) aren't hub-centric or lug-centric. It's the **fitment** of the wheel to the hub that's hub- versus lug-centric.
    If the wheel's centerbore fits up closely on the hub so the wheel is centered on the hub 'as is' (without the lug nuts being threaded), then it's a hub-centric fitment.
    If the wheel's centerbore is larger than the hub, so that the wheel isn't centered until the lug nuts are threaded on, then it's a lug-centric fitment.
    A wheel may have a lug-centric fitment on a smaller hub but fit up hub-centrically on a larger hub matching its centerbore.
    It less confusing to think of it in terms of 'hub-centered' versus 'lug-centered'.
    The lug nut style doesn't determine the type of fitment, and the fitment type doesn't determine what type of lug nuts are used. The lug nuts need to be the type suited to the wheel's lug holes, regardless of the fitment type.
    Having said that ... Tapered-face style lug nuts are arguably better suited to lug-centric fitment because the tapered mating surface helps guide the wheel into a centered position and keep it there based on the lug nuts alone.
    All 1st generation OEM Tacoma wheels are designed for a hub-centric fitment.
