What is in my oil filler neck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RA77, Mar 18, 2022.
  1. Mar 18, 2022 at 10:31 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    That looks like the guy next to me last time on the indoor shooting range! I don't go there anymore...to many yahoo's. I don't want to guess what that was he was holding!
  2. Mar 19, 2022 at 12:46 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    As post #9 and 13 said short trips - hope that's it.
    Clean it out, change oil and run it on a good drive getting hot. You may have to clean it out again as a small quantity of water may still be in there on engine internals and get deposited by the timing chain up in the filler neck and oil cap. Check your radiator when cool and see if any mess in there. Worst case is head gasket. See you bought it used last year so who knows what/how the previous owner drove it and the maintenance that was really done. Add a bottle of Heat or additive with methanol to remove any possible water in your gas also. Do the easy stuff and go from there as best odds are too many short trips and not fully warming up.
    RA77[OP] likes this.
  3. Mar 19, 2022 at 3:12 AM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    At this point OP needs to weigh in with more details to confirm or rule out short trips (compounded by cold climate) as being the potential root culprit.
    Naveronski, Wulf and winkel like this.
  4. Mar 19, 2022 at 7:43 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Mine looked like that a few years ago when it was really cold,and I only drive 6miles to work. Wiped it out best I could and went for an hour drive to get her nice and warm. Now,if you have that on your dipstick,you've got a problem.
    Accipiter13, RA77[OP] and Wulf like this.
  5. Mar 19, 2022 at 8:33 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    What's the oil look like?
    Oil catch can.
  6. Mar 19, 2022 at 11:18 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Short trips, moisture never has a chance to burn off.
  7. Mar 19, 2022 at 11:23 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Reminds me of this girl I dated in High school. :bananadead::anonymous:
    Seriously, short trips? Op needs to provide a few more details.
    jackn7 likes this.
  8. Mar 19, 2022 at 11:26 AM
    timbobzimbob
    timbobzimbob Well-Known Member
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
    As a Canadian who lives 4 minutes away from work I'm all too familiar with this. Always have to clean out the milkshake crap on the filler neck on oil changes. Nothing to worry about though, it's exactly what post #7 said. I did get a few oil analysis' done for shits and there were no issues with condensation in the oil
    Here's mine lol
    RA77[OP], y=mx+b, TegoTaco and 4 others like this.
  9. Mar 19, 2022 at 11:27 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    do you have a misfire code?
    could be head gasket leak. or water/humidity in the intake
  10. Mar 19, 2022 at 11:31 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Pretty much every one will find gook like that in the oil fill cap. Short runs stop and go.
  11. Mar 19, 2022 at 11:34 AM
    Jtac15
    Jtac15 Well-Known Member
    Long island
    2022 Trd OR
    Happens if you only drive short distances mostly. There isnt anything wrong with the vehicle.
  12. Mar 19, 2022 at 11:36 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Excessive moisture. Can happen from, short trips without letting the engine reach and maintain operating temp for extended periods, could be a thermostat issue, or water intrusion
  13. Mar 19, 2022 at 12:14 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Do you change your oil every ~4k mi?
    Or do you only drive ~4k mi a year?
  14. Mar 19, 2022 at 1:08 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    OH MAN! THAT'S GROSS! That goop in my humble opinion seems to suggest a leaky head gasket.
  15. Mar 19, 2022 at 2:31 PM
    #35
    Jtac15
    Long island
    2022 Trd OR
    When you only travel short distances and dont get out on the hwy much it doesnt heat up enough to burn off the water vapor. Its normal
    RA77[OP] and cadcam2002 like this.
  16. Mar 19, 2022 at 4:39 PM
    #36
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Just drive it and get up to temperature for good distance. Pretty sure it will be mostly if not all gone.
  17. Mar 20, 2022 at 11:43 AM
    #37
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Short trips that's been stated. Run it for a longer trip here and there it magically disappears.
    RA77[OP] and Beerline123 like this.
  18. Mar 20, 2022 at 11:52 AM
    #38
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    All these confident replies that "its just short trips, dont worry, go for a long drive" seem a bit misplaced in their level of conviction.
    Probably the better way to characterize the situation is this:
    • A) Highest likelihood (? 80% or more ?) is that it's just due to short drives & engine / oil not heating up enough to drive out condensation moisture. Fix: Go for more long drives at highway speeds (? 30 minutes or more ?) to heat things properly and drive out accumulated moisture.
    • B) Less likely ( 20% ??) but far more serious would be any situation where coolant (water/glycol based fluid) is leaking into the engine & contaminating the oil. Failed seal or gasket somewhere.
    Best way to quickly assess: drain a few ounces of oil from the oil sump & see what the color of the oil is. If it looks any shade of "milky", from light tan to dark brown milkshake, a B) situation is probably the cause & should be further investigated and fixed soon.
  19. Mar 20, 2022 at 12:35 PM
    #39
    Jtac15
    Long island
    2022 Trd OR
    RA77[QUOTED][OP] and GilbertOz like this.
  20. Mar 20, 2022 at 12:46 PM
    #40
    GilbertOz
    GilbertOz Driver
    CA
    This is a good vid -- instead of taking the trouble to drain ounces out of the oil pan, just pull the dipstick & inspect the oil color & consistency that way.
