What is in this radiator?!?!?
Discussion in 'General Automotive' started by novanut21, Aug 13, 2012.
  1. Aug 13, 2012 at 8:31 PM
    novanut21
    novanut21 [OP] Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    It look and feels like black RTV. Could this be some form of stop leak? I changed the radiator and cap flushed cooling system and a week later I pulled the cap off and more of this stuff was stuck to the underside of the new radiator cap. Also the radiator in question is on my 2000 Camaro SS.
  2. Aug 13, 2012 at 8:44 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Looks like rust. Did you put antifreeze back in after the flush or just water?
  3. Aug 13, 2012 at 9:08 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Pre mixed antifreeze
  4. Aug 13, 2012 at 9:14 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    wow that looks like shit. try just pull out the whole radiator n the main hoses n flush it all out. stick a hose in the rad when u pull it n flush it.
  5. Aug 13, 2012 at 9:15 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    Looks like stop leak to me. Maybe some rust too.
  6. Aug 13, 2012 at 9:17 PM
    JeremyGrey
    JeremyGrey Well-Known Member
    Ahwatukee, AZ
    2012 DCSB TX Pro Prerunner
    I had this problem on my jeep. IMO, you probly have a air leak somewhere causing oxidation. I tightened some hoses, flushed the radiator and got a new cap and it solved the problem.
  7. Aug 13, 2012 at 9:24 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    I ordered new upper and lower hoses and im going pull the coolant reservoir and flush it out. I'll double check all hose clamps and see if I can get a loaner cooling system pressure tester. What troubles me is it came back after flushing and installing a new radiator and cap after only a week. Other than that I dunno what else to do. Thanks for the input guys!
  8. Aug 13, 2012 at 9:26 PM
    IGO4LOW
    Zach
    Fullerton, CA
    Electrolosis...?
    Just throwing that out there. Happened in my bronco. Aluminum radiator + non dexcool + ground = crap similar to that.
  9. Aug 13, 2012 at 9:34 PM
    JeremyGrey
    Ahwatukee, AZ
    Yeah, I think that's what mine was. Similar anyway
  10. Aug 13, 2012 at 9:38 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    looks like antiseaze! prob a stop leak. ive never seen oxidation in the radiator but that looks super thick
  11. Aug 13, 2012 at 9:54 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Added to list of possibilities. I'm running dexcool antifreeze.
  12. Aug 13, 2012 at 9:57 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    LOL if so I wouldnt be as mad I'd be more like :yay: hell yea my car makes free nutella!!
  13. Aug 13, 2012 at 10:07 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    That could be the problem.
  14. Aug 13, 2012 at 10:35 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    I thought so too but looking at my reservoir on my GMC Sonoma and inside the radiator it looks nothing like this and I havent changed the antifreeze since I bought it with 60,000 miles on it and I dont believe the previous owner did either and now it has almost 120,000. It has some brown sludge in it but nothing like in the pic. The stuff in the pic is black and rubbery like a silicone sealant. I can take pieces of it and stretch it.
  15. Sep 8, 2012 at 2:36 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    I think he's saying Toyota recommends their own long-life coolant and not Dexcool which could be causing the problems. Honestly I've seen cars switched from orange to green to premixed prestone and haven't ever seen a problem. Only thing I have seen is dexcool gel up every so often when it's used in extended applications.
    Like others have said a complete flush of the radiator. If it's solidifying though I have no idea, sounds like the making of trouble though.
  16. Sep 8, 2012 at 3:13 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Sorry I did not specify, the radiator is in my '00 Camaro SS.
