What is involved in a Transmission mount replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZMan2k2, Sep 22, 2022.
  1. Sep 22, 2022 at 6:58 AM
    ZMan2k2
    ZMan2k2 [OP] “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    I’ve got an ‘06 DCLB auto 4x4 with 190k kms. I also have only hand tools.
    My X-mission mount is failing. I get a clunk in the drivetrain when I’m on the gas, coast then get back on it. It also happens when shifting into gear or from P->R.
    I have no leaks at X-mission, X-fer case or rear differential. My U-joints and CB are new (less than 5k kms). I’m not sure what to look for in a failing mount, but from research, that’s my suspicion.
    Advice welcomed. Let me know what else to check, or how to check the mount. Thanks.
  2. Sep 22, 2022 at 7:06 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Check ur U bolts where the leafs meet the axle. When mine were/are loose the axle moves ever so slightly that it causes that feeling. I believe it's called axle wrap. Something simple to check before u dive into the transmission mount.
    Ricardo13x likes this.
  3. Sep 22, 2022 at 7:08 AM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    A video would help.
  4. Sep 22, 2022 at 7:28 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    U-bolts were installed by a shop when I had my leafs replaced. I’m starting to wonder though. They’re tight, I checked 80ft-lbs.
    steelcity2[QUOTED] likes this.
  5. Sep 22, 2022 at 7:49 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  6. Sep 22, 2022 at 9:32 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    Thanks @TnShooter and @steelcity2 . Looking at the pics, and reading the descriptions, looks like my X-mission mount is good, about 1/16” of up travel. Going to look into my U-bolts next. These were cheap Amazon ones, all I could spend at the time.
    steelcity2 likes this.
