What is it??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doug355r, Mar 4, 2010.
  1. Mar 4, 2010 at 11:53 AM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Darn, I was hoping for passenger ejection seat.
  2. Mar 4, 2010 at 11:54 AM
    rc51ny
    rc51ny Well-Known Member
    It looks familiar---I think it's for the landing lights---for when you're on final approach???:D
  3. Mar 4, 2010 at 11:58 AM
    doug355r
    doug355r [OP] Well-Known Member
    Phoenix, AZ
    2017 Tacoma TRD Sport
    2.5" Lift with King shocks and TC UC, 4.88 gears, ARB compressor, ARB lockers, S POD, cheap lights
    Probably.
    If i press the button and hold it. then my remote key unlock/lock still works. The horn just doesn't honk, so I'm assuming the alarm isn't activating.
  4. Mar 4, 2010 at 12:02 PM
    DaWillDaBeast
    DaWillDaBeast Well-Known Member
    Will
    Colorado
    05 Tacoma 4x4 with some goodies
    Things
    My horn never honks??? am i broken :(
  5. Mar 4, 2010 at 1:09 PM
    doug355r
    Phoenix, AZ
    Does it go..."beep beep" when you use remote to lock your doors?
    I think my alarm is a dealer installed one, ie not from the factory.
  6. Mar 4, 2010 at 1:34 PM
    DaWillDaBeast
    Will
    Colorado
    Things
    Nope, when i use my remote to lock my doors the only thing that happens is my lights flash, no noise though.....
  7. Aug 24, 2011 at 12:40 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    I have a stock Toyota alarm in my truck- no button though. Only a small microphone and "security" led in the center console by where the A-Trac button would be.
    It does not do anything if you have the key in the truck. If the little red truck symbol in the center of your dash is on or flashing, it has read that the key is near.
    Try this- open your windows and use your fob to lock the truck. Chirps twice. Then put your fob and key 30 feet from the truck (however far it is that the RFID chip cannot read the key). Walk back and open the doors by reaching in through the window. Run back and get fob to shut off horn gone wild.:D
  8. Aug 24, 2011 at 2:18 PM
    myname150
    myname150 Well-Known Member
    I guess it's different if you have just an Immobilizer and no alarm? The security light for me doesn't stop until I actually put the key in.
    But even then, the 09 Camry we have has toyota's alarm system, and even with the key in the car and unlocked (but not in the ignition), the security light still flashes.
    And I don't think you need to go so far to test the alarm. Just open the window before you shut off the truck. Set the alarm, wait till the security light goes from steady on, to flashing that means the system is armed. Then pull the door handle open and see if the alarm goes off.
  9. Aug 27, 2011 at 3:18 PM
    84Hilux
    Gary
    Vancouver, Canada
    Sorry, my bad. You are right- the light does not stop flashing until key is in the ignition.
  10. Aug 27, 2011 at 4:07 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I think it’s a gyroscopic bangalorum controller manual override do not use the override at speeds below mach 1.
