What is making this squeaking sound?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BigD20, Mar 8, 2010.
  1. Mar 8, 2010 at 6:01 AM
    BigD20
    BigD20 [OP] Member
    Dustin
    Virginia
    2000 Tacoma TRD V6
    Hey guys, I have a 2000 Tacoma and just recently it started squeaking. It's very noticeable when I begin to reverse and it makes a squeak, squeak, squeak sound..kind of in sync with the wheels turning. I thought it may be the u-joints, so I greased them up real good and the squeak is still there. It sounds like it is mainly coming from the rear. What could it be? Any and all suggestions would be appreciated..thanks!
  2. Mar 8, 2010 at 6:08 AM
    DieselTech
    DieselTech Well-Known Member
    Jeremy
    Nova Scotia
    2005 Taco
    3" Lift, Eagle Alloys, 285/75 Mickey Thompson BAJA's, Flowmaster 40 series, 8000k HID's, Low-pro tool box, 7" touchscreen with JBL speakers and sub,
    Might be your pads, The wear tab on the inboard pad is made to squeak once your pads are worn, you'll notice is when your on the brakes, and in reverse.
    From the rear it could be somthing simple,,, rust flakes in the drum? take your drum off and check your secondary shoe (front one) and make sure there is nothing wedged in there, or rust flakes, or maybe even a chip in the shoe.
    Good luck
  3. Mar 8, 2010 at 6:29 AM
    BigD20
    BigD20 [OP] Member
    Dustin
    Virginia
    2000 Tacoma TRD V6
    Thanks man..I'll check the rear pads and see if I see anything out of the ordinary
  4. Mar 8, 2010 at 6:52 AM
    bgdeer1
    bgdeer1 Well-Known Member
    minooka il
    tacoma prerunner
    3 inch lift in back 1 1/2 front. 31' mesa A/T's. Alpine deck, alpine speakers, l5 kicker solo baric sub
    i had that exact prob.. u joints!
  5. Mar 8, 2010 at 7:43 AM
    98tacoma27
    Ben
    Not Beech Creek
    It could also be the rear leafs. If they get rusty or some dirt in between them they will squeak.
  6. Mar 8, 2010 at 9:36 AM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    u-joints or center support bearing or both
  7. Mar 8, 2010 at 9:58 AM
    BigD20
    BigD20 [OP] Member
    Dustin
    Virginia
    2000 Tacoma TRD V6
    So the noise is definitely not coming from the rear brakes. The squeak sounds like it is coming from where the drive shaft connects to the rear axle..somewhere in there. I greased up the u-joint. Why would it only squeak in reverse?
  8. Mar 8, 2010 at 10:01 AM
    stro908
    stro908 Well-Known Member
    Jared
    Sparta,NJ
    SR5 TRD 4banger man.
    my 2001 was doing the same thing. I lubed all the zerk fittings and it was still doing it. I greased them some MORE and it has now been gone for almost a month.
    I used 2 tubes of grease, they were very dry!!
  9. Mar 8, 2010 at 11:10 AM
    BigD20
    BigD20 [OP] Member
    Dustin
    Virginia
    2000 Tacoma TRD V6
    I have greased all the fittings..the squeak is still there..IT'S DRIVING ME CRAZY!
  10. Mar 8, 2010 at 11:20 AM
    DieselTech
    Jeremy
    Nova Scotia
    2005 Taco
    Chech for play in the u joints? What about the rear pinion seal, give that a check, have you be having a slow leak of rear end oil at all?
  11. Mar 8, 2010 at 6:04 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    well if u checked all the u-joints its 99.9% gonna be center support bearing mine started to squeak in reverse so i changed it now no more squeak:cool:
  12. May 10, 2010 at 6:37 PM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    Mine just started doing the same thing. Went through and greased everything, still doing it. Dosen't squeak when in neutral rolling backwards. Thinking maybe u-joint. Anybody else figure this out?
  13. Jan 5, 2011 at 12:16 AM
    v1ndictiv3
    v1ndictiv3 Well-Known Member
    Bay Area, California
    '98 PreRunner Xtra Cab 2.7L
    Mostly stock: AFE Pro Dry S Filter, Bedrug, Leer Shell, 265/75/15 Goodyear Wrangler RT, Husky Liners, Wet Okole seat covers... Powertrax No-Slip in the near future =)
    Bump to see if anyone's fixed their squeak...
    My 98 prerunner has just started squeaking (sounds kind of like a bird chirp) and it's driving me insane! Sounds like it's coming somewhere from rear right side of truck. It's not constant, usually when I'm around 20-30mph and coasting (subsides when I accelerate or brake). Guess I'll start checking bolts and lubing everything and hope that works. Can't stand the squeak!
  14. Oct 31, 2015 at 12:05 AM
    Aufmitdemspiel
    Aufmitdemspiel Member
    98' 4wd V6 Tacoma
    Major bump... I have noticed this. Are there any for sure results? Mine does it when in first gear as well.
  15. Oct 31, 2015 at 5:41 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Most of the time it is a bad u joint. Possibly the carrier bearing (spray some penatrating lube into both sides. This usually stops the squeaking for a bit).
