What is that high pitch squealing/whining noise?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NeedHelp808, Jul 16, 2019.
  1. Jul 16, 2019 at 6:18 PM
    NeedHelp808
    NeedHelp808 [OP] New Member
    2000 Tacoma 3.4L V-6
    03 Tacoma 4x4. Help?! Pressed the brake pedal and heard a high pitch squealing/whining noise coming from the engine area while pressing on the brake pedal. Noise stops when brake pedal is released.
  2. Jul 16, 2019 at 6:22 PM
    eon_blue
    Azusa, CA
    Are you sure it's not coming from the brakes themselves? Usually when you hear squealing while braking it's because the pads are getting low and need to be changed, or you have dirt/rock/road grime stuck between pad and the rotor causing it to squeal when you brake.
    Brake pads have a little metal piece built into them so that they intentionally squeal when getting low to let you know that they need to be replaced.
  3. Jul 16, 2019 at 7:10 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I don't know what a failing brake booster sounds like but it might be suspect, being that the noise is only while you have pedal pressed down
  4. Jul 16, 2019 at 8:46 PM
    jmonteil
    jmonteil Well-Known Member
    San Diego, CA
    99 Tacoma Limited 4WD
    882 5100 3 Leaf AAL 285/75r16 - Ko2
    Does it only happen when your GF is riding with you?
  5. Jul 16, 2019 at 10:57 PM
    jtakeda
    jtakeda Well-Known Member
    2002 Turd
    Are you saying the squealing happens when youre completely stopped by the car is running?
  6. Jul 17, 2019 at 9:29 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If it's only happening when you're pressing on the brakes (and still moving), it's very likely your front brake pads are just worn out and need to be replaced.
    When the brake pads wear down, eventually a piece of metal is exposed that makes a horrible sound when pressing the brakes.
