What is that nosie?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTRD420, Jan 18, 2010.
  1. Jan 18, 2010 at 6:25 PM
    TacoTRD420
    TacoTRD420 [OP] ( . Y . ) = :)
    Jake
    Kaplan,La.
    2011 FJ T.T.
    Toyota FJ TT...Pretty much stock.
    I have a some nosie coming from the front on the driver side inside. Cant find what it is. It does it when i hit bumps and it sound like a little bird, and pissing me off. Anyone would know what it is?
  2. Jan 18, 2010 at 6:27 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I dont know but judging from your username? Are you just high when you hear it?:confused: LOL, Im jk bro, but seriously, not sure what the sound is.:cool:
  3. Jan 18, 2010 at 6:35 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Obviously it could be quite a list of things.
    One I am familiar with is the fit of the front quarter panel against the top of the bumper.
    This happened to me and I proved it by wedging a piece of cardboard between the bumper and front panel. Happened to me on the drivers-side actually.
    Ended up having to tweak the panel (bend it inward) to prevent the sound. I heard it most when traveling down rough dirt roads.. drove me nuts!!
    Best wishes finding the source of yours.
  4. Jan 18, 2010 at 6:39 PM
    TacoTRD420
    Jake
    Kaplan,La.
    2011 FJ T.T.
    No man. thats the cc of my atv. damn i hope someone knows
  5. Jan 18, 2010 at 6:43 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Uniball UCAs squeak when they get within 20ft of anything remotely dirty. PB Blaster will fix it for a little bit. Cleaning the uniball really well as part of regular maintenance will help.
    Or its the heim joint at the bottom of the coilover. That one also squeaks pretty good when it's dirty. Mine just recently stopped squeaking which makes me think its about to explode out of my wheel well.
  6. Jan 18, 2010 at 6:51 PM
    TacoTRD420
    Jake
    Kaplan,La.
    2011 FJ T.T.
    whats the best thing to clean the uniball?
  7. Jan 18, 2010 at 6:56 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    When I had my UCAs completely off the truck I went after them with a pressure washer and shop towels to get the really stuck on stuff. Road gunk and built up PB blaster won't just get cleaned up by any solvent. You're stuck using elbow grease.
  8. Jan 18, 2010 at 6:59 PM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I clean/lube my TC UCA uni's with "Tri-Flow" It's a teflon based lube I actualy get from my bike shop. The stuff is amazing. Also chris4x4 said this is what to use on your uni's. So if you don't and use somthing else you head will explode!:D
  9. Jan 18, 2010 at 7:01 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Hell every mod on my truck had it's own noise. People that I drove around thought the wheels were gonna fall off, I could explain every click, whistle, squeak, and thud. The UCAs just blended in with the rest of'em.
  10. Jan 18, 2010 at 7:06 PM
    Bearskill
    Sac
    I need to secure my rear wheel wells better. The clips holding that thin plastic is lose. Seriously sounds like a drum roll when I hit wash board.:rolleyes:
  11. Jan 18, 2010 at 7:13 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Just means you need to go faster. Then it'll just be a steady drone. Gettin sleepy just thinking about it.
  12. Jan 18, 2010 at 7:18 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Fabtech Lift on top of 3 inch body lift. 34s trail grapplers on 18inch eagle alloys. KRFab Rear bumper, BHLM with HIDs, TRD seat covers, Hood scoop, N fab tire carrier, black valence, TRD intake, 40s Flowmasters, Foglight mod, best for last and thats my 4.56 gears, and much more too come.
    Finally someone with the exact same problem as I do. You only have it in the front driver side right? Every time i hit a bump or something it starts to churp or something like a bird. I've tried cleaning everything but i still cant gget that dumb sound out its killing me.
  13. Jan 18, 2010 at 7:20 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Lube every metal on metal contact you can think of. That's how I found the bottom of the coilover, where it attaches to the lower A arm, was squeaking. Hell one of my squeaks was my All Pro bumper taking the paint off the front quarter panel underneath the headlight.
  14. Jan 18, 2010 at 7:21 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    bent skid plate
  15. Jan 18, 2010 at 7:26 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    thanks man I'm gonna have to try that out and see if it finally stops. What lube did u use wd40 or something else?
  16. Jan 18, 2010 at 7:27 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Maybe after I lube everything and get it all checked maybe itll stop and I can tell you whatsup Jake.
  17. Jan 18, 2010 at 8:41 PM
    doodle_cakes
    doodle_cakes Well-Known Member
    Canada
    08 Taco SR5 5lugger
    I used to hear a high pitch chirp sound when I would press the gas pedal. It was pretty quiet, usually only would here it with my tunes off. If I repeatedly pressed my gas pedal lightly it would do it every time, sounding like a bird chirping.
    I think I told the dealership but they couldn't find any unusual sounds... big surprise. I think it just went away on its own.
