what is that smell?
Discussion in '1st Gen. Tacomas (1995-2004)' started by trmarshall1, May 18, 2012.
  1. May 18, 2012 at 12:33 PM
    trmarshall1
    trmarshall1 [OP] The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    So yesterday, on my way home, I went to pass this guy on a slight upgrade just after a stop light. I was doing about 25 in 3rd gear, and tried downshifting to 2nd. It didn't want to go into gear, so I tried sticking it back in 3rd, no luck for a few seconds, then I started to smell burning oil, thick and heavy smell of oil. Could see no smoke, oil pressure light didn't illuminate, checked oil when I got home and it was good. Also, I had no further issues and haven't smelled it since. Any ideas, maybe tranny oil needs changing? With as strong as the smell was, it has me concerned.
  2. May 18, 2012 at 12:34 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Sure it wasn't the clutch burning?
  3. May 18, 2012 at 12:41 PM
    twistax
    twistax Toyota Freak
    Carlsbad NM
    2017 Tacoma 4x4 Off-Road
    CaliRaised ditch mounts & Side Projecting pods
    Gasket leaks near the manifold?
  4. May 18, 2012 at 1:00 PM
    trmarshall1
    Tim
    San Jose, CA
    Very well could have been. Never burned one before:eek:, this is my fifth manual vehicle...would that smell like I described it?
  5. May 18, 2012 at 1:04 PM
    acdronin
    acdronin Well-Known Member
  6. May 18, 2012 at 1:08 PM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    A burnt up clutch smells just like burnt up brakes. have you ever driven passed a semi Truck that had smoked his breaks? Or have you ever driven an older vehical with out abs and questionable brakes hit the breaks at a great amount of speed and by the time you got to actually stopped the brake pedal was on the floor and there was a funny smell? thats what a smoked clutch smells like.
  7. May 18, 2012 at 1:11 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    well usually you only smell a clutch burning when you are riding the clutch. (which would result in a backhand from mom, since she is the one who taught me how to drive a manual) unless you have something else going on with it. then those pressure plates get hot and burn its a very sharp nasty smell. and it will come up from the floorboard. since you were having trouble getting it into gear, it sounds like the clutch was not fully engaged.
    and even if you had gridded the gears for a second or two that would not cause the smell.
  8. May 18, 2012 at 1:14 PM
    trmarshall1
    Tim
    San Jose, CA
    LMAO, I knew someone would hit me with the Skynyrd! Yeah, come to think of it, it did smell quite a bit like burning brakes. So is the clutch going out? I also notice every now and again, it's rough putting her in reverse and it'll click when it drops in.
  9. May 18, 2012 at 1:16 PM
    acdronin
    Once you do get it in gear it runs fine? Then I would be thinkin clutch from what you describe
  10. May 18, 2012 at 1:20 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    me either.
  11. May 18, 2012 at 1:22 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Nice bump
  12. May 18, 2012 at 1:36 PM
    A_Ninja_Racer
    Tampa, FL
    smoking your clutch once isn't the end of the world. I would keep driving it. If it starts to give you problems with shifting through the gears with normal driving then yes you need to get a new clutch and prolly resurface the flywheel. but if it doesn't give you any problems I wouldn't worry about it. Another thought and forgive be because I don't know does your toyota have a hydrolic clutch or a cable clutch? The possible reason you smoked your clutch could be either the clutch master cylinder or the clutch slave might be starting to fail and when you pushed the clutch pedal in it didn't fully disengage the clutch.
  13. May 18, 2012 at 1:58 PM
    trmarshall1
    Tim
    San Jose, CA
    Me too...
  14. May 18, 2012 at 2:03 PM
    trmarshall1
    Tim
    San Jose, CA
    Sheeeiittttt, no idea. It's a 2002 TRD. How would I figure that out, I'm no mech, but I'm willing to learn. That's why I joined TW.
  15. May 18, 2012 at 2:47 PM
    A_Ninja_Racer
    Tampa, FL
    If you have a hydrolic clutch there will be a small resivuor with break fluid in it just to the left of your brake master cylinder. At least every time I've seen ine it was to the left.
  16. May 18, 2012 at 4:24 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    Sometimes you guys are more work than your worth... Remember, there are women on this forum so be respectful of their desire to come on the forum and not have to see this stuff.
  17. May 18, 2012 at 8:42 PM
    trmarshall1
    Tim
    San Jose, CA
    Thanks, I'll check it out. And mods, sorry.
