what is the best 3" lift and why.
Discussion in 'Suspension' started by jastampke, Jul 2, 2011.
  1. Jul 3, 2011 at 3:49 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Yup and thanks for helping me when i bought it.. I'm still running stock UCA's and got a good alignment. Barley any wandering on the interstate, i guess i got lucky..
  2. Jul 3, 2011 at 3:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I'd have to look at your alignment print out to see if you "got lucky", but if its driving good, thats the main thing. Odds are, the alignment shop had to dial in more camber, to get you the min. Caster, so keep an eye on the outside tire wear.
  3. Jul 3, 2011 at 3:52 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    I installed an ICON suspension this weekend, and could not be happier. Wash board roads have no chance!! If you have the extra cash, go ICON.
  4. Jul 3, 2011 at 3:57 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    You got 4.5" in the front and your cv angles are pretty good?? :confused:
  5. Jul 3, 2011 at 3:57 PM
    krimson
    krimson Nothin
    TRD Off Road
    I did get an alignment sheet, but threw it away so i don't remember what my Caster, Camber, and Toe is. So far I have 2K miles on my KM2s and no signs of uneven wear yet. When looking at my truck straight on my Camber is titled in a little.
  6. Jul 3, 2011 at 4:23 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    yeah actually not that bad i have seen alot worse on here with less of a lift idk either. its sits at about 4 1/4 now i'm thinking it will end up at around 4 or very close that should put me pretty nice. i did do the diff drop and i know they don't make much more than a couple degrees difference in cv angle but, it obviously did something to combat it.
    here are the pics from the day the lift was put in. lol don't get me wrong they aren't great either but, they don't seem that bad to me if t settles down to 4 i think it will be fine:)
  7. Jul 3, 2011 at 4:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Wholey shit! Those are some steep angles! Your inner CV fins are touching...
  8. Jul 3, 2011 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OP, Going over 3" lift in the front is a bad idea. Stick to 3" as a max. lift. You loose down travel when lifting, and the truck only has 8" stock. So lifting 3" will net only 1" or so down travel as it is.....
  9. Jul 3, 2011 at 4:37 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I think you can officially stop telling people your " CV angles are actually pretty good "
  10. Jul 3, 2011 at 4:54 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i know it will be a problem in the future if it does not settle down. i bought a complete 3 inch lift this is just what it came out to. i had heard that the pro comp kits are usually higher than stated but, even i was shocked when the shop told me the measurements i had to go confirm my self and it was 4.5 sure enough.
    if it settles to 4 inches it will iron out a bit i hoping it goes a bit lower than that but, that may be wishful thinking on my part.
  11. Jul 3, 2011 at 4:56 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    no shit oz.
  12. Jul 3, 2011 at 4:59 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    i was told by the shop they were not great but, they had seen alot worse. i was also told that they should end up decent after it settles down.
  13. Jul 3, 2011 at 5:01 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    and the smart ass comments commence. thanks guy i'll take that under advisement.
  14. Jul 3, 2011 at 5:08 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    How can one not be comforted by the old, 'I've seen worse' statement.
    ...even better when it comes from the guy walking out of the back room holding the plunger...
    (No extra charge....appearing nightly all this week.....try the veal....)
  15. Jul 3, 2011 at 5:13 PM
    #35
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    if you want to spend the money... buy some KING coilovers from DSMS. I think they are pre-load adjustable to 3" someone will correct me if i'm wrong
  16. Jul 3, 2011 at 5:32 PM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The "Ive seen worse" probably meant that the guy has seen broken ones....
  17. Jul 3, 2011 at 5:38 PM
    #37
    dmbtiger19
    dmbtiger19 Well-Known Member
    Columbia, SC
    2010 Prerunner TRD SR5 Timberland Mica
    I'm assuming you have 4x4. If so, I would say go with the OME lift 886 (you thank yourself later) and TC UCA for the front.
    If you are lucky like some and have a prerrunner then go the camburg route. Camburg 4" spindles and UCA, stock springs and 5100s.
    Either way this well have you sitting between 3.5" and 4" in the front, so for the rear grap some all pro leafs and 5100 or 5125.
    This is my plan anyways.
  18. Jul 3, 2011 at 5:44 PM
    #38
    OZ-T
    Peter North
    British Columbia
    No need to get hormonal on me , I was just stating a fact .
    You keep saying your CV angles are fine when clearly they are not , that's all .
    No hate
  19. Jul 3, 2011 at 5:54 PM
    #39
    Dmxsam123
    Dmxsam123 Active Member
    sean
    Florida
    11 2wd 4 door full cab sr5
    Bilstein shcoks with Toytec coil overs on or ome Shocks with coils, for a 3 inch lift?
    And in the rear for better ride quality should I get a rear block or add a leaf, either way I will be adding after market rear shocks?
    Can anyone help me?
  20. Jul 3, 2011 at 5:56 PM
    #40
    Dmxsam123
    sean
    Florida
    Also I have a 2wd,four door full double cab if that helps
