What is the best 6" lift kit?
Discussion in 'Suspension' started by Grantman, Nov 13, 2012.
  1. Nov 14, 2012 at 7:14 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    oh right i forgot he's had both, a drop bracket set up and a custom mid travel :rolleyes:
  2. Nov 14, 2012 at 7:16 AM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    Ive had drop brackets before and never had issues with them as well..
  3. Nov 14, 2012 at 7:17 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    TW, where everyone knows everything about everything.
    OP, get the type of lift you want. At the end of the day, you are the one spending your money on your truck that you are going to drive everyday. Don't get something you think you are going to regret later.
  4. Nov 14, 2012 at 7:26 AM
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    Id put my drop bracket up agents your 3inch any day.
    dpf88101, Mario2278 and Socal562 like this.
  5. Nov 14, 2012 at 7:32 AM
    Namyo
    Namyo -
  6. Nov 14, 2012 at 7:34 AM
    PLC721
    Patrick
    Chandler, Az
  7. Nov 14, 2012 at 7:52 AM
    cgs2k2
    cgs2k2 old man
  8. Nov 14, 2012 at 7:55 AM
    Large
    Large Red
    Go with ProComp or Fabtech, looks nice and will do decent in the sand.
  9. Nov 14, 2012 at 8:05 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    and i'll put my LT against your DB... all daylong..
    gr8tacsprt10 and 10trdtaco like this.
  10. Nov 14, 2012 at 8:05 AM
    MonkeyProof
    SoCal- SGV
  11. Nov 14, 2012 at 8:09 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    ^^^^^ hahaha..... take the DBs
  12. Nov 14, 2012 at 8:35 AM
    Specalt
    Phoenix
    2001 TRD 4x4
    Any Day
  13. Nov 14, 2012 at 8:36 AM
    Namyo
    Namyo -
    pixels :cool:
  14. Nov 14, 2012 at 8:38 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    :bored:
  15. Nov 14, 2012 at 8:40 AM
    #35
    cgs2k2
    cgs2k2 old man
    MINE IS THE BIGGEST DICK OF ALL
    mlcc and Capitol_Eric like this.
  16. Nov 14, 2012 at 8:43 AM
    #36
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    i had a bad expierence with a mid travel set up and went to the RCD 4.5 DB and i love it... to each his own it boils down to use, preference, style
  17. Nov 14, 2012 at 8:53 AM
    #37
    Specalt
    Phoenix
    2001 TRD 4x4
    I'm just saying that a 6 inch lift does not take away from the function of a lifted truck and make it only a mall crawler. As Taco me elmo stated. Both are viable solutions on and off road.
    You have just as much ground clearance from the lowest point of the truck, if not more clearance with the 6 inch. It is all about tire size.
    Yes you have to cut the fame, but you bolt in a bracket that is just as strong factory bracket. The peace of steal I cut out was only about 2 pounds. Once removed from the truck. The pace I put in its place was about 25 ponds of steal, ant it bolted into the stock lower control arm holes.
  18. Nov 14, 2012 at 9:06 AM
    #38
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    A drop-bracket lift will work fine for your needs. On soft sand you'll want a large footprint, so fitting larger tires and airing them down should be what you're after.
    A note on the tire size though. You mention 305/70R15 but also mention 17" rims. Note that the tires you specify are for a 15" rim. Make sure you double-check everything before placing an order or you're gonna have a bad time.
  19. Nov 15, 2012 at 2:02 AM
    #39
    Grantman
    Grantman [OP] Well-Known Member
    Grant
    Hampstead, NC
    2011 Tacoma 4X4 supercharged
    TRD supercharger
    So why did you switch from the 6" to the 3"? Did you have to weld the cross member back in?
  20. Nov 15, 2012 at 2:12 AM
    #40
    Grantman
    Grant
    Hampstead, NC
    TRD supercharger
    my mistake, 305/70R17
