what is the best backspacing
Discussion in 'Wheels & Tires' started by 02tacomav6, Feb 15, 2012.
  1. Feb 15, 2012 at 1:34 PM
    02tacomav6
    02tacomav6 [OP] Member
    Brody
    Chesapeake
    2002 Tacoma V6 3.4
    hello everyone i have been doing some research on backspacing and offset but i still dont know what backspacing or what offset I should get. I want to run a 33x13.50R16 on a 16x10 rim but i dont know the proper backspacing to use. Can you help me or give me any information that could help me. thanks
  2. Feb 15, 2012 at 8:01 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
    That's a really odd tire size. Why do you want to go so wide? You are going to rub like crazy no matter what backspacing or lift you have.
    4" backspacing is probably what you should get. I've seen a few 16" rims that come with 3.75 backspacing which would help to push the tire out a little bit, but that backspacing is harder to find on a 16" rim.
  3. Feb 16, 2012 at 5:49 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You are going to rub like crazy, even with a lift.
  4. Feb 16, 2012 at 2:48 PM
    02tacomav6
    Brody
    Chesapeake
    2002 Tacoma V6 3.4
    thanks, i figured i would but i like the look of kinda low and wide so i was gonna through a 3in body on there when i get the money for the rims but i guess i will have to go with the 33x12.50 tire instead
  5. Feb 16, 2012 at 2:51 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Go with the 33X12.5 with a 3.75 BS. you might still rub a little though
  6. Feb 16, 2012 at 3:02 PM
    John Cheong
    John Cheong Active Member
    East Bay, CA
    2001 SR5 PreRunner
    33" falken rocky mountian A/T, 3.5" fabtech lift, Deck plate mod, Painted badges.
    the farther out your wheels are the more stress it puts on your wheel bearings. if you wanna go that wide then get a lift and trim your quarter panels. or if your not too rough on your truck you could get wheel spacers but those also put more stress on suspension parts
  7. Feb 16, 2012 at 5:21 PM
    02tacomav6
    Brody
    Chesapeake
    2002 Tacoma V6 3.4
    i figured i would put a 1in spacer or less on it with a 12.50 but no more than 1", i dont do a whole lot of wheeling the occasional mud puddle here and there and a ditch or two:)
  8. Feb 16, 2012 at 5:51 PM
    TexasTacoma37
    The spacer will make the rubbing worse.
  9. Feb 16, 2012 at 5:58 PM
    02tacomav6
    Brody
    Chesapeake
    2002 Tacoma V6 3.4
    Thanks for that warning, i was just looking for an easy way to get that wide look. looks like im back to the drawing board again for the 100th time:mad:
  10. Feb 16, 2012 at 6:00 PM
    TexasTacoma37
    You can't really pull off the super-wide look on these trucks without fiberglass fenders or cutting your stock fenders.
  11. Feb 16, 2012 at 6:13 PM
    02tacomav6
    Brody
    Chesapeake
    2002 Tacoma V6 3.4
    Yea thats two much for my pay-grade, thanks for all the advice guys
  12. Feb 21, 2012 at 3:10 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
