What Is The Best Bug and Tar Remover?
Discussion in 'Detailing' started by Rickochet, Aug 26, 2017.
  1. Aug 26, 2017 at 10:41 AM
    Rickochet
    Rickochet [OP] Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I have a nice herd of bugs on my grill that washing and pressure washer won't get off. I had some old Turtle Wax bug and tar remover but it didn't do much. It was also almost like a liquid wax. I remember some bug and tar remover that was thin like mineral spirits. Can someone recommend a good bug and tar remover?
  2. Aug 26, 2017 at 10:44 AM
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
  3. Aug 26, 2017 at 10:47 AM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Wd40 or goof off (strong stuff , I don't how well it works on paint thou )
  4. Aug 26, 2017 at 10:54 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    for the tar, wd-40 or even better, a little bit of straight gasoline on a rag will wipe it right off. For the bugs, high pressure sprayer.
  5. Aug 26, 2017 at 11:07 AM
    Rickochet
    Rick
    Kentucky
    Car wash pressure and my pressure washer didn't take it all off. My grill and bumpers are painted and don't want mess up the paint. How does WD 40 work on painted surfaces?
  6. Aug 26, 2017 at 11:17 AM
    bluezzy
    Monty
    Eugene, Oregon
    It dont sound like you believe me but gasoline will not hurt your paint. I get it on my motorcycle tank all the time and now and then I get some on the truck paint when filling it up at the gas station and never hurt it all, ever. You could try it on a non visible area and find out for yourself.
    Toyopet2wd likes this.
  7. Aug 26, 2017 at 11:42 AM
    Paulhood77
    Paulhood77 Well-Known Member
    2012 White Tacoma 2.7L
    Grez-off made by Spray Nine works great
  8. Aug 26, 2017 at 12:32 PM
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    I use Duragloss Bug Remover & a Bug Sponge. Duragloss will not remove any wax/sealant either. I'm sure Autogeek will have a nice Labor Dale sale next week also.
    NMTrailRider, CusterFan and ace96 like this.
  9. Aug 26, 2017 at 12:50 PM
    Team Flatline
    Team Flatline Not squatin' w/ my spurs on...
    Eric
    Up a creek, Fla
    PreRunner
    Maxtrac'd, Icons, Dakars...........
    For the bugs, a wet dryer sheet. Works like magic.
    REDNECKTEX likes this.
  10. Aug 26, 2017 at 4:13 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Stoner's Tarminator.
    ace96 likes this.
  11. Aug 26, 2017 at 4:57 PM
    tacotrucktrd15
    tacotrucktrd15 That's a positive on the negative.
    ORD
    MMXV MGM TRD Sport 4x4
    Automotive Goo Gone or Jet fuel has worked for me.
  12. Aug 26, 2017 at 5:03 PM
    Roland79
    Roland79 Well-Known Member
    Dave
    Missouri
    2017 TRD Off Road DCLB Black
  13. Aug 26, 2017 at 5:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    WD40 or mineral spirits will get most things.
  14. Aug 26, 2017 at 6:14 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  15. Aug 27, 2017 at 4:46 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I have a bug and tar sponge I got on Amazon. When dipped in hot water it gets pretty soft so it's clear coat safe.
    Use caution when removing bugs, let them sit in water for a bit before going after them (you can get some hot water and car soap in a spray bottle and hit them a few times to pre-soak them). Then carefully remove them with a sponge or microfiber towel.
    Don't use any harsh chemicals. It's not great for your paint long term. Your clear coat could haze from damage over time. The best thing to do with this is prevention not treatment. Use a high quality sealer on your paint. It prevents the bugs from sticking so bad. And again don't use harsh chemicals because you'll strip the sealer off.
  16. Aug 27, 2017 at 5:25 AM
    Rickochet
    Rick
    Kentucky
    I have the dealer applied Zylon paint protection which helps but the bugs still stick.
  17. Aug 27, 2017 at 5:29 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    @MTgirl tells me she sprays bugs with Windex. Soak a few minutes and rinse off.
    Have not tried it myself yet.
    Her Runner gets a LOT of bugs though since she's in the mountains every weekend.
  18. Aug 27, 2017 at 5:29 AM
    PackCon
    Connor
    How old is the coating?
  19. Aug 27, 2017 at 5:32 AM
    Rickochet
    Rick
    Kentucky
    The hood and grill was redone four years ago. Supposed to be good for 5 years. Water still beads up on the hood like it did when the Zylon was first applied. My truck stays in my garage more than it is out so maybe that helps the Zylon work longer. My dealer always has a Zylon demo vehicle in the showroom. The actually apply some spray paint to the hood, let it dry then run a finger through the paint and it comes right off.
  20. Aug 27, 2017 at 5:36 AM
    PackCon
    Connor
    If you have a coating, I would especially stay away from any harsh chemicals or removers. Stick with car soap and water and just take your time. You will strip a coating eventually with any harsh products.
    You can still use a sealer on top of a coating to prevent any sticking. You can also use a wax if you garage the truck and don't drive a lot of miles. I'd clay and apply a wax to the front end every 4-6 weeks. Bugs should come right off.
