What is the best Jack to carry in your Tacoma??
Discussion in '1st Gen. Tacomas (1995-2004)' started by tommyboy480, Feb 23, 2020.
  1. Feb 24, 2020 at 8:21 PM
    tommyboy480
    tommyboy480 [OP] Well-Known Member
    tom
    2003 Toyota Tacoma TRD SR5 Prerunner
    Fuel Wheels,BFG ko'2 tires, Fox Suspension, Bear cross drilled rotors,LC Engineering rack and pinion ,K&N Filter, Weather tech,Spyder headlights and tail lights, led HD conversion bulbs, and a hell of a lot of new factory parts!!
  2. Feb 24, 2020 at 8:23 PM
    gunnar#1
    gunnar#1 Well-Known Member
    sam
    Mesa
    2001 Tacoma 4x4
    Silver xtra-cab,old man emu 3 inch lift, 2016 wheels, arb front bumper, receiver hitch, Automatic transmission cooler, tundra front calipers, new frame.
    Hi lift is nasty, I had better luck off road with wood a small bottle jack and a small scissor jack
    Ritchie likes this.
  3. Feb 24, 2020 at 8:25 PM
    tommyboy480
    tom
    So good day today!! went all out ,Installed a new tool box on the truck,Found a new little jack from Harbor Freight, I have a nice Recovery setup on the truck, my minds at ease now..
    cruiserguy likes this.
  4. Feb 24, 2020 at 8:29 PM
    tommyboy480
    tom
    Forsure,its just my road side kit,plan on getting a jack that's just for the trails,plan on mounting rack on camper,and mount my trail jack up there,,
    just started building this truck again..
    I bought the truck new,and was my daily driver for years,was sitting for 6 years in my shop,,now im getting back into hooking it up..it will be there soon..
  5. Feb 24, 2020 at 8:31 PM
    gunnar#1
    sam
    Mesa
    2001 Tacoma 4x4
    I was trying to use harbor freight jack just like the one above off road and it had to be bled a lot so maybe store it straight up and down.
    tommyboy480[OP] likes this.
  6. Feb 24, 2020 at 9:20 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I can't imaging trying to carry a floor jack around. I use one for working in the driveway, but out on the road, I just use my bottle jack that came with the truck. I also carry a few pieces of wood, 4x4, 2x8 for added lift if I need it. Harbor freight makes some decent floor jacks for the money. But so far I've been lucky, I've never had to jack up my truck anywhere but home. I've on my second set of Hankook Dynapro At, and only had one flat, but I managed to plug it in place and limp home.
  7. Feb 25, 2020 at 7:29 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    What box is that?? That's a nice looking setup!!
  8. Feb 25, 2020 at 3:57 PM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    I’ve got the stock bottle jack in my truck as well. Having the OME lift kit with the AAL has given me a 3” lift and don’t think the stock bottle jack will cut it, if I get a flat. I’m considering some accessories from this company: https://safejacks.com/, a Hi Lift jack (which I need to learn how to use properly & safely), or an ARB jack mentioned in the previous post. The blocks of wood is also a good idea to carry with you as well.
  9. Feb 25, 2020 at 4:31 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    A lift alone doesn't change the usefulness of the stock bottle jack. Your control arms and axle are all at the same height unless you're rolling larger tires.
    I have 32's (265/75r16's) and the stock jack still works fine (on flat ground).
    Those safejack accessories are pretty cool for sure.
  10. Feb 25, 2020 at 4:56 PM
    gunnar#1
    sam
    Mesa
    2001 Tacoma 4x4
    I have the OME 2 ice with 32's and the factory jack is only good under the rear end, which is definitely dicey off road
  11. Feb 25, 2020 at 6:57 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Why do you need to carry a hydraulic jack in a 1-GEN Tacoma?
    Just the scissor jack in case you need to change a tire. They never break down otherwise. :thumbsup:
  12. Feb 25, 2020 at 11:03 PM
    tommyboy480
    tom
    Its a Husky Box I got a Home Depot ,model #102300-9-01 and 102300-53-01 ..its actually made to sit on the bedsides of Tacoma ,ford ranger, Nissan ect,,but it worked out perfect..I actually like the cut out at the bottom because it makes it where it doesn't hit the wheel wells,,
    Thanks for Your Reply.!!
    chrslefty[QUOTED] likes this.
  13. Feb 25, 2020 at 11:12 PM
    tommyboy480
    tom
    Man,!!,safe jacks.com has some nice little Bottle jack setups, mite get one of those kits to throw in the tool box,,will take up less room too..
    Thanks for sharing that!!
    Hamer95USA[QUOTED] likes this.
  14. Feb 26, 2020 at 1:26 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    great, a website with more shit I want to buy.
  15. Feb 26, 2020 at 1:28 PM
    #35
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    KingZee likes this.
  16. Feb 26, 2020 at 1:55 PM
    #36
    Krupkey
    Krupkey Member
    How did you secure the box in place?
  17. Feb 27, 2020 at 6:05 PM
    #37
    tommyboy480
    tom
    I put four bolts though the bed of the truck with washers, and lock nuts. Honestly it was solid after two bolts ..
    You just have to be careful, put box in place where you want it, make sure the lid is going to open all the way.
    Mark it with pieces of tape. Then measure where you think you want to install your bolts, then get under the truck and measure to make sure there going to work, and not hit anything..i measured 12" inward, and 7" back from cab.then the second bolts where 4" over and 6" back from the first bolts installed. If that makes any since.
    Hope that helps!!
  18. Feb 27, 2020 at 6:07 PM
    #38
    tommyboy480
    tom
    Ordered that Safe Jack Kit from 4wheelpars yesterday, going to pick it up tomorrow when I get my Deaver Leaf Springs, ill Take pictures and let you all know how I like it..
    Thanks for all the info and help!!!
    Hamer95USA and cruiserguy like this.
  19. Feb 27, 2020 at 6:17 PM
    #39
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    I follow a guy on IG who swears by it. It definitely looks legit.
  20. Feb 27, 2020 at 6:23 PM
    #40
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I love that you are the original owner :cool: And even though it quit being your daily driver you still held onto it because you knew what a great reliable little truck it is:D one of the most beautiful things I've heard in a while
    :D:rofl::rofl:
    It is freaking cool though:cool:
