What is the best paint to use on the radiator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hookedontronics, Oct 5, 2010.
  1. Oct 6, 2010 at 6:10 AM
    hookedontronics
    hookedontronics [OP] Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    So i really have nothing to worry about then, correct?
  2. Oct 6, 2010 at 6:43 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    That's what I meant by not relevant. Keep it thin and while it may have some affect, it's minimal and in the vast majority of cases won't be noticable. Also, it's the AC radiator getting painted, not the coolant radiator.
    Doing this is just a matter of looks. Toyota may believe that non-black is fine, since they then don't need to have the added cost of paint for that part. "If man were meant to fly, he'd have wings."
  3. Oct 6, 2010 at 6:48 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Correct, most aftermarket condensers are painted black and they work fine.
  4. Oct 6, 2010 at 7:03 AM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    There is heat transfer lost but the effects are so minor,and i mean minor that even with extreme conditions such as towing your limit, you will not even know ( I have tested this). Just make sure it is a light coat! Remember the idea is to darken, not completely paint it. Also remember not to clog the fins!!
    And I used flat black engine paint. If your engine does overheat for what ever reason I don’t want burning paint!
    PS: very little paint covers the radiator because what you see is the AC condenser!
  5. Nov 7, 2010 at 12:15 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Yes, which DOES inhibit heat transfer, will raise the head pressure of your A/C system, cause your compressor to work harder and greatly decrease the lifespan of your system.
    And no, I'm not talking out of my ass.
  6. Nov 7, 2010 at 2:21 PM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    X2 -Same, I cleaned everything off first and did not paint the bugs! :D
  7. Nov 7, 2010 at 2:23 PM
    Taco4x4NC
    David
    Any flat black high temp paint will work.
  8. Nov 7, 2010 at 2:34 PM
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    I don't agree with that. It costs money to paint a radiator and they figure most people won't be switching out their grill so why should they pay to paint a radiator that most people will never see.
  9. Nov 7, 2010 at 2:51 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    If Toyota wanted our trucks to have...
    ...a stiffer rear suspension they would already come with the 4-leaf packs. [​IMG]
    (Canadians excluded)​
  10. Nov 7, 2010 at 3:03 PM
    ShaLor
    Shane
    Burbank, CA
    How about this stuff?
    http://www.eastwood.com/eastwood-radiator-black-paint.html
    From their website:
    Eastwood Radiator Black Paint
    Standard engine paints are too thick for radiator use because they can interfere with heat transfer and block air flow between the cooling fins. Also, standard paint tends to flake off radiator tanks. Radiator Black helps solve this problem. Durable Enamel formulation resists temperatures up to 250ºF, gas and chipping. One can covers 6 square feet (most radiators require 2 cans). Net wt. 12 oz.
  11. Nov 7, 2010 at 5:05 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    all in all an A/C condensor is still considered a radiator b/c it is still transferring heat..I mean just to be technically technical :)
  12. Nov 8, 2010 at 1:27 AM
    AU DIGG3R
    AU DIGG3R Active Member
    Sacramento, CA
    07 TRD Sport DC LB 4x4
    I use to work in a radiator shop a long time ago, after a overhaul or any fin or tank work we would paint them. I never asked about the paint specifically. I would agree about not painting it for maximum cooling, but then again, they do come with paint on them.
    To bad it was a metal tank, I would say just polish it, they are typically brass.
  13. Nov 8, 2010 at 11:23 AM
    ShaLor
    Shane
    Burbank, CA
    Your shop is not the only radiator shop to do that. I used to work at a Cadillac dealership and whenever we had a radiator rebuilt, I was the one to bring it to the radiator shop. EVERY radiator we brought in the be worked on would come back with a fresh black paint job.
  14. Nov 8, 2010 at 11:28 AM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    new sig! :rofl:
  15. Nov 8, 2010 at 11:34 AM
    #35
    TiMe
    TiMe Well-Known Member
    CA
    05 Dbl Cab 4x4
    6" Fabtech with coilovers 33" nitto mud grapplers
    I just used some satin black made by dupont (I get it thru my work). Didnt worry about paintin that stuff back there. Its not gonna hurt anything.
    If you were to powdercoat it or use some crazy thick paint then you MIGHT have problems with heat transfer. Regular ole paint isnt thick at all and wont hurt anything.
    Just my .02 :D
  16. Nov 8, 2010 at 12:04 PM
    #36
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Bottom Line: If you want to do a proper clean looking mod take 30 seconds and spray it with a hose and wipe it dry before you apply a light coat. If your worried about heat transfer, take 30 seconds and spray it with a hose and wipe it dry before you apply a light coat.
    ...... Reading threads like this make me want to cry inside. Hopefully I can settle this once and for all. Here's my opinion, if you want to know why then read it all.
    First Off, The Creds : I have a 4th Class Power Engineering Degree (almost have my 3rd Class) with a Red Seal valid across north america and pretty much everywhere in the world. Reason for this is because we follow all the CSA (Canadian Standards Association) and ASME (American Society of Mechanical Engineers) Standards that most of EARTH adheres to. So "Not talkin out me ass" ;)
    Second off, the science: Heat is actually energy, and heat transfer is the ability of one material to move heat energy from one source hotter Material to another colder material. Heat energy transfers naturally from Hot to Cold (which cools the hotness and warms the coldness), never from cold to hot... ever. The more materials this energy transfer has to go through, the slower the heat transfer. Take insulation for example, it works because theres microscopic air bubbles between the material. so for heat to move from the fiber to air to fiber to air takes forever. Since the surface areas are so small for the heat to transfer through these different materials. Or in the case of say a radiator, cold air moves over the LARGE SURFACE AREAS (aka: All the fins) removing the heat from the metal.
    third off, My professional opinion: Putting on a THIN layer of flat black BBQ paint, Which is designed to stick to metal surfaces. Will have such a negligable effect you wouldn't notice the difference in the life of your vehical and it wont cause any stress on your cooling system. Just clean the surface with a little wash so that it sticks to the radiator properly.
    I'd be more worried about the guy who said "just throw it on over all the dirt and dead bugs it'll work fine" ... just wow man... really???... even though in all honesty that would probably only raise your operation temps by a degree, which don't matter. your operating temps change based on what season it is more.
  17. Nov 8, 2010 at 12:13 PM
    #37
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    haha. you guys are funny for arguing about this.
    just do a light coat of the high temp rattle can and youll be fine. don't want to do a lot of coats. just enough to get rid of the shine.
  18. Nov 8, 2010 at 12:14 PM
    #38
    FlyingTaco
    FlyingTaco Well-Known Member
    GA
    '10 4x4 DCSB SWB
    Trimmed mud-flaps, engine de-tick, FJ wheels, avid off road light bar(one of a kind), truck covers bed cover and decals by sockmonkey so far.....
  19. Nov 8, 2010 at 12:18 PM
    #39
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yea and we use rust proofing paint on the inspection man ways on our boilers. the rest of the boiler is insulated and metal cladded. So Guess what? every where does things differently but its not a "No way to paint".. your systems not gonna overheat and blow from a thin layer of paint..
  20. Nov 8, 2010 at 12:20 PM
    #40
    ShaLor
    Shane
    Burbank, CA
    Yeah, what he said! :popcorn:
