What is the best seal kit for Gen 2 Tail gate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Solocam, Feb 7, 2020.
  1. Feb 7, 2020 at 7:18 AM
    Solocam
    Solocam [OP] Member
    I was wondering about what tail gate seal kit works the best for the Gen 2.
    Thanks
    R/Mike
    LostCaliTaco likes this.
  2. Feb 7, 2020 at 4:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Feb 7, 2020 at 7:29 PM
    Solocam
    Solocam [OP] Member
    Thanks Tn Shooter
  4. Feb 7, 2020 at 10:27 PM
    682bear
    682bear Well-Known Member
    West GA
    2006 SR5 DC and 2015 TRD OR DC
    I used some self- adhesive weatherstripping that I found at Home Depot... a roll was about $7 and works great.
    -Bear
  5. Feb 7, 2020 at 11:46 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Just a note that if you have a shell or cover and you have any water leaks/intrusion like most of us do at some point/weather conditions and you seal that bottom tailgate gap up tight there will be nowhere for the water to run out. Dust is my worst enemy when a covered bed get it all sucked up and into the cargo. I have a bed matt so water runs under it in the hard bed plastic grooves.
