what is the best way to clean a dirty engine?
Discussion in 'Detailing' started by tacomabuddha, Apr 15, 2010.
  1. Apr 15, 2010 at 6:05 PM
    tacomabuddha
    tacomabuddha [OP] BUDDHApower
    SoCAL
    05 Prerunner TRD
    Hi, i was wondering what is the best way to clean a dirty engine without hurting the wires or anything that's under the hood. Can you just hose it down wit h2o? Please help :confused:
  2. Apr 15, 2010 at 6:40 PM
    tacomabuddha
    SoCAL
    05 Prerunner TRD
  3. Apr 15, 2010 at 6:43 PM
    SantaCruz'n
    SantaCruz'n Well-Known Member
    Logan
    Temecula
    Saving for the 2013
    I was wondering the same thing.
  4. Apr 15, 2010 at 6:49 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
  5. Apr 15, 2010 at 7:34 PM
    tacomabuddha
    SoCAL
    05 Prerunner TRD
  6. Apr 27, 2010 at 8:09 PM
    salttram
    salttram Member
    Brian
    San Pedro, CA
    01 SR5 4X4 TRD XTRA CAB
    I use a motorcycle-specific cleaner called S-100. They say it's formulated to protect rubber and plastic. Simply spray it on, wait a few minutes and use moderately strong water spray to wash down the engine area. It has worked well for me. Any time I remove spark plugs, intakes or any part that exposes interior parts, I like for the engine area to be as clean as possible.
    I cover any large electrical plugs, orifices and such with blue painter's tape, spray liberally with S-100, maybe scrub around a little with a soft brush, wait a few minutes and hose it down with a moderate jet spray. I'm always amazed at how nice everything looks when I'm done.
    Two important things to remember: 1. Immediately wash-off any S-100 residue that might have gotten out side the engine bay (it will have) and 2. Seal-off your spark plug holes as best you can. If your truck runs like crap after washing your engine bay it's most likely that some water got down into a spark plug well.
    S-100 is not cheap but I think it's worth it. Makes my KLR 650 look "almost" new!
  7. Apr 27, 2010 at 8:11 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    WD-40 is incredible! Makes everything look brand new! Takes away all the "caked" in mud that is in the rubber hoses
  8. Apr 28, 2010 at 2:46 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    I cover up the altenator with a rag and plastic bag and then spray Simple Green on the engine and let it sit for a few seconds and then spray it all down. Works good.
  9. Apr 28, 2010 at 4:12 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    x2! this is what i did. just barely spray it down with water doing little areas at a time. engine looks brand new!
  10. Apr 28, 2010 at 6:30 AM
    soilsample
    soilsample Well-Known Member
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    CD-2 engine detail spray is terriffic. Get it at Autozone.
    Leaves everything looking great and won't attract dust.
    Also works great under fender wells.
  11. Apr 28, 2010 at 6:34 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Becareful with the Simple Green as it is caustic to aluminum. They make an Aluminum safe variety.
  12. Apr 28, 2010 at 8:12 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Thanks for the tip. :D I just googled it and it says it can cause aluminum to corrode faster.
  13. May 4, 2010 at 2:20 AM
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    i got a nice write up on the socal forum
