What is the black plug in the back of the factory stereo? (2011 TRD OR DC)
Discussion in 'Audio & Video' started by ezatnova, Jun 17, 2013.
  1. Jun 18, 2013 at 4:40 PM
    2012tacolover
    2012tacolover Well-Known Member
    Norm
    CA/AL
    White PreRunner TRD Sport DCSB
    Tinted Windows, Black Nerf Bars, LED Dome & Map Lights, Snugtop Xtra-Vision, WeatherTech Digitalfit front and rear, trimmed Front Mud Flaps, BFG A/T KO's, Matt123 White Skid, Devil Horn Emblem Wet Okole front and rear seat covers! Future Stuff: Lift and new Wheels! :)
  2. Jun 18, 2013 at 6:47 PM
    medic2230
    Murph
    Bama! Roll Tide
  3. Jun 18, 2013 at 6:58 PM
    ribby95
    ribby95 Member
    Baja Edition
    Some stock HU come with a stereo upgrade port (usually subwoofer w/amp). From the looks of the wires, it defiantly has something to do with sound. (always the slight chance it could be something else.) Some of these plugs also tie into other sensors. I have almost the exact same plug on my f150 stock hu and it was for a line driver for a subwoofer with built in amp. ill try and do some digging with a couple of installers I know and see what they say. If you have local shop just stop by and im sure they can test it and tell you exactly what it goes to. Hope this helps.
  4. Jun 18, 2013 at 7:08 PM
    medic2230
    Murph
    Bama! Roll Tide
    Are all your speakers working? They must be cause when I installed my Kenwood all mine hooked up to the two right connections and the two left ones were left open. I lost my steering wheel controls though. So it must be the big white connection for the steering wheel controls.
  5. Jun 18, 2013 at 8:59 PM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    21 DC TRD OR - Voodoo
    Wildpeak 265/75/16, Headstrong Progressive AAL, 5100's w Emu 885s
    Thank you guys for the links. I haven't found an answer from that info yet.
    To the last question, yes, I believe all the speakers do work when it's unplugged. I messed with the fade and balance and it seemed like sound could be isolated to each area just fine. I did hear the separate tweeters too.
    Hopefully we're getting close to an answer. I can't be the only one with this plug, or the only one who will try to install an iPod kit and run into this port having a plug already, so hopefully when we get an answer, it will help some others down the line, as well.
  6. Jun 18, 2013 at 10:20 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Well the taped wires I mentioned earlier are absolutely 100% the "shield" or "-" side of an RCA, now weather its audio or video I couldn't tell you. But I can say that the only thing on a stock radio that would use that type of input is either the AUX port down below, or the camera input, or the bluetooth mic, or usb. If both those still work, its possible that its not audio or video and instead just a ground for whatever source it goes to.
    If it a 2011 non-JBL, the only plugs or sources you should have are the following:
    Power
    6 speaker audio
    SAT Radio tuner
    SAT Radio antenna
    AM/FM antenna
    Bluetooth input/output (microphone included)
    Steering controls
    USB (if you have it)
    And that's all I can think of... Someone add something if I missed it.
    If all those still work (be sure to check Bluetooth mic) then the plug probably isn't used.
  7. Jun 19, 2013 at 4:19 AM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    Thanks ProForce.
    I do not have Bluetooth buttons/mic in the truck.
    I also do not have USB (I wish I did, so I could skip this whole darn ipod kit!).
    I am 99% sure all 6 speakers work with the black plug out. I made an effort to listen to the tweeters themselves too.
    The camera and the Aux port are both confirmed working with the plug out.
    I don't understand what the unit/car has for XM Satellite very well, so this is one of the possible areas where it could be related. I was under the impression that in this radio/year, the Sat receiver was integrated into the head unit, meaning that there wouldn't need to be anything plugged into the head unit to make Sat work. Also, and this could be key, the XM Preview channel 001 works FINE with the black plug out too! So strange.
    Lastly, I looked at that black wrapped wire you mentioned a little closer. As I think you are already saying, it definitely is a thicker, twisted strand, bare metal wire that is wrapped in a type of tape. It's different from the other 11 wires in the thing that have normal colored dipped coating, and I believe are solid and not twisted strand.
  8. Jun 19, 2013 at 4:55 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    I did some researching (VERY bored at work) and I have an answer for you. That black wire you disconnected is a R9 wire. R9? R9 is the "Radio Option Connector"
    How do I know? I attached the wiring diagram (in .txt format) for 2005-2008 Standard to 2011 JBL radio diagrams. You have a non-jbl radio (86120-04200) and from the diagram, that connector is called R9. Open the file, scroll down a little to see what R9 is! :D Beers on you :cheers:
  9. Jun 19, 2013 at 5:04 AM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    j.nguyen, now we are getting somewhere. I'm about to pour you a frosty cold one (it's never too early, right?), but now I just want to know what the heck is plugged IN to my "radio option connector"! That's what seems to be empty on most other people's radios. What am I disconnecting by unplugging that R9, or what might I have that I don't realize (just bought the truck last week, used). It isn't something hacked and aftermarket. Those 12 wires go right into the factory loom out of the stereo.
    Thanks :thumbsup:
  10. Jun 19, 2013 at 6:03 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    If it's free, I'll take it! I can research and google all day, but I am not an expert in wiring. Hopefully someone can chime in and help ya!
  11. Jun 19, 2013 at 10:41 AM
    ProForce
    Anthony
    Alaska
    OP, your correct that XM is built in, that's why the sat antenna plugs right into the head unit. There is nothing else that this plug could be used for. Since the diagrams state its a "radio option" that would make complete sense, hence the reason your iPod connection goes there. But whatever is plugged in there obviously doesn't lead to anything. Its definitely 100% OEM and not a dealer add on, its factory. Probably just a plug that was on the harness and not used. Just like trucks without fog lights can remove the blank and have the wires and plug plugged into the blank. Its a standard harness. I'm guessing it was something to do with Bluetooth.
    My professional opinion would be to go ahead and disconnect it and leave it out. I can guarantee it won't cause any issues with the truck and if you eventually notice something not working that's audio related then you probably know why lol. I'd plug in the iPod and call it a day!
  12. Jun 19, 2013 at 11:12 AM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    Thanks. I agree. Sure jsut seems strange though that there's a plug in there, vs everyone else acting like theirs is empty.
    I'm going to keep hunting, and maybe someone who has been in this situation before me can comfirm something 100%, whether it's a blank, or a pre-wire, or what. You'd think those 12 wires have to go somewhere and do something!
    Anyway, if I can get a GTA ipod kit that works (first one sounded awful and had tons of static, so it's getting exchanged), then I'll try to keep an eye out for what that black plug might be. Worst case, there's $15 Y plugs on ebay, so I could put the black one back in, and add the ipod plug too.
  13. Jul 4, 2013 at 5:30 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Looking at the doc j.nguyen posted, the pin descriptions are interesting. Last time that I remember seeing CD audio descriptions like that was on a Cd-drive on a computer for the analog audio output. Along with the ACC and B+ to power something, could it be a patch for an audio processor or Crossover? Seems antiquated to me, but does the CD work with it unplugged? Id check on mine, but my 2006 doesnt come close to yours on features.
  14. Jul 4, 2013 at 5:43 AM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    Thanks Dragons. The CD plater (6 disc built in to the head unit) does work fine when that's unplugged. The mystery is still open for solving!
  15. Jul 22, 2013 at 7:25 AM
    #35
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    anyone closer to solving this problem?
  16. Jul 22, 2013 at 7:35 AM
    #36
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    Ha, nothing definitive yet. The best "guess" so far (from my Toyota mechanic friend) is that it's some pre-wiring for Bluetooth that doesn't go anywhere. Seems odd to me.
  17. Jul 22, 2013 at 1:15 PM
    #37
    apoteker
    i also am confused by this plug although it is not black in my 2012
    and it does not seem to have any essential function wtf? it sure is confusing
    IS THIS perhaps the usb input wiring connector? my 2012 has this plug with lots of wires into it but no other explanation...
  18. Sep 12, 2013 at 1:10 PM
    #38
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    subbed for the wiring diagram
  19. Jun 13, 2014 at 4:56 AM
    #39
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Bump...
    I ran into this issue yesterday as I was installing my iPod interface too. I thought it was the satellite radio, but after reading this thread, obviously not. Also nothing seems to be affected with mine unplugged. I don't have the Bluetooth either. I'm guessing that's what it could be. I wish someone knew to put my mind at ease. LOL. OP, you still around, and have you had any adverse affects from it being disconnected?
  20. Jun 13, 2014 at 5:33 AM
    #40
    DrFunker
    DrFunker Well-Known Member
    really?:rolleyes:
