what is the correct psi
Discussion in 'Wheels & Tires' started by mitiko, Oct 6, 2008.
  1. Oct 6, 2008 at 9:41 PM
    mitiko
    mitiko [OP] Well-Known Member
    lax
    05 prerunner trd
    hi. what is the correct psi fot OEM tires size 16''
  2. Oct 6, 2008 at 9:43 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Should say it in your driver door i forget what it is off the top of my head someone will chime in
  3. Oct 6, 2008 at 10:06 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    29 front
    33 rear???
    Don't quote me thats just my memory.
    On a side note I've always wondered why the front (with all the weight of the engine and such) is less. Just doesn't seem to make sense.
  4. Oct 6, 2008 at 10:39 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I'm quoting because I think you're right. I checked the door sticker before checking the factory Dunlop 16's. They came inflated to 50# each. I just left them there.
  5. Oct 7, 2008 at 3:59 AM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    I prefer mine a with a little more air than normal maybe 1-2 psi more. Feels a little better to drive....
  6. Oct 7, 2008 at 6:05 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i found on the 06 access cab prerunner i had....running 34 in the front and 31 in the rear was nice and mileage was still good.
  7. Oct 7, 2008 at 10:17 AM
    TacoNut
    Adam
    Denver, Co
    It's all about personal prefernce really... Obviously if you spend a lot of time on loose terrain you'd want your pressure a little lower, where as if you spend all your time on pavement keep them a little bit higher.
  8. Oct 7, 2008 at 10:18 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    exactly!!
