What is the difference between these two lifts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrMackey89, Nov 3, 2013.
  1. Nov 3, 2013 at 7:28 PM
    MrMackey89
    MrMackey89 [OP] Well-Known Member
    Andrew
    Georgia
    2011 TRD Sport 4x4 Double Cab
  2. Nov 3, 2013 at 7:36 PM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    One has the coils prebuilt with new bushings and top mount. It also comes with rear Ubolts and axle shims
    Preassemble usually $100-150
    Ubolts - $50
    Shims - $30.
    They probably added extra markup because most people dont have the skill or tools to assemble the coils themselves.
  3. Nov 3, 2013 at 7:38 PM
    MrMackey89
    Andrew
    Georgia
    Do I need the new ubolts with the top one?
  4. Nov 3, 2013 at 7:47 PM
    Vantage
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    Yes. U bolts should always be a 1 time use item. If you take them apart, you SHOULD throw them away.
    As for length, I needed longer Ubolts for my toytec AAL, the stock ones wouldn't have worked even if I wanted to use them.
    Both kits look to use the single Toytec AAL.
