What is the differential ratio on 2005 tacoma TRD sport 4x4?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AmableTRD, Jul 21, 2023.
  1. Jul 21, 2023 at 4:20 PM
    AmableTRD
    AmableTRD [OP] New Member
    2005 black Tacoma TRD Sport 4x4
    stock
    What is the differential ratio on 2005 tacoma TRD sport 4x4??
  2. Jul 21, 2023 at 4:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Door jam sticker will give you your build codes and tell you what you need to know (assuming no one's regeared it).
  3. Jul 21, 2023 at 4:25 PM
    AmableTRD
    stock
    You have the table codes??
  4. Jul 21, 2023 at 4:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Does no one look anything up?
    Last spoon
    A = 8.0"/205mm
    B = 8.8"/225mm
    01 = 3.583:1
    02 = 4.100:1
    03 = 3.153:1
    04 = 3.727:1
    05 = 3.307:1
    06 = 4.300:1
    07 = 3.909:1
    A = Open
    B = E-Locker
    C = Limited Slip Differential
  5. Jul 21, 2023 at 4:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If it’s a 4.0 engine.
    It is 3.73
    The exception being the XRunner.
    Since you are 4x4. That’s isn’t you.
    SUMOTNK, TRDSport10 and sparkystaco like this.
  6. Jul 22, 2023 at 12:53 AM
    TacoTuesday1
    SD CA
    Probably 3.73.
    Only one I've heard to be 4.10 stock would be:
    2.7L inline 4, 4x4, manual, which may either come as reg cab or access cab
    which is where I bought my extra ring and pinions from
    SUMOTNK likes this.
