What % is the factory tint?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Negative1, May 28, 2009.
  1. May 28, 2009 at 5:55 AM
    Negative1
    Negative1 [OP] Well-Known Member
    I picked up my new 09 taco last night (woohoo) love it. I'll post pics when it stops raining here.
    I have an appointment to get the driver and passenger windows tinted. I just need to know what Toyota uses for tint on the rear access cab windows and rear slider window?
    I just want it to match up.
    Thanks!
  2. May 28, 2009 at 6:08 AM
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    i had it tested when i had my front windows done
    came out as 18% on the sides and 30% on the back window
  3. May 28, 2009 at 6:10 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    I have 35% on the fronts which turn out to look exact looking from inside the cab out, but looks a little lighter in most light when looking from the outside in. alot also use 20%. a big factor of it matching from the outside is the brand of tint they use, I have noticed different brands of tint have a slightly different shade when you look at it from the outside
  4. May 28, 2009 at 6:10 AM
    Negative1
    ok, so I guess 20% on the doors would best match up with the access cab windows?
  5. May 28, 2009 at 6:46 AM
    FL4x4Taco
    FL4x4Taco Well-Known Member
    On my D.C. I went thru heck with a local shop. They put 15% on the front to "match". What a joke. It looked 2x's as dark. The front measure 77%, Rear doors are 27%. I plan on putting 35% Solargard (HP Supreme I believe) on the front windows and calling it a day. FYI, in FL the tint laws are 28% F, 15% R.
  6. May 28, 2009 at 6:55 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
  7. May 28, 2009 at 6:56 AM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    5% all around:)
  8. May 28, 2009 at 7:09 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I went with 20%, not quite as dark as the back which is fine as tinted windows are illegal in California anyways.
    :anonymous:
  9. May 28, 2009 at 10:17 AM
    powerban
    powerban Well-Known Member
    SoCal
    09 PreRunner DC LB Sport
    I was told that the factory tint does not have the UV protection that aftermarket tint has. If you're getting tint to keep cool, then you should tint all the way around. Minus the windshield of course.
  10. May 28, 2009 at 12:12 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    I got 20% on the fronts and 35% on the back on top of the factory tint. The brand was Solar Guard. If you put 20% on the front, it would be darker than just the factory tint. 35% would match the back.
  11. May 28, 2009 at 1:50 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    I just had the 35% done to my fronts and it matches as noted above.
    Here in Arizona 35% is the legal limit on front windows. :cool:
    Yuma Taco,
  12. May 28, 2009 at 2:30 PM
    HIGGI
    HIGGI Member
    hi desert
    2009 pyrite mica dc o/r 3"lifted debadged
    35% is the closet match
  13. Apr 7, 2010 at 6:10 PM
    glandnut
    glandnut Grease Monkey
    Florida
    09' MGM TRD DC Sport LB(gone), 16' 4Runner Trail
    secret stuff.
    Just had the tint man check my stocker window doublecab- rear was 28%, front was 76%. went with Llumar 30...
  14. Apr 7, 2010 at 6:44 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    thats what i got. looks good.
  15. Apr 7, 2010 at 7:09 PM
    stephbm6
    stephbm6 Well-Known Member
    West Jordan, Utah
    2006 TRD Double Cab
    I was told by the tint place I went to that my factory tint was 20% so I put limo (5%) on the back 3 windows over my factory tint. It looks good but I can't see shit backing up at night :)
  16. Apr 7, 2010 at 7:14 PM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    front 2 are 80% all the black looking glass is 25%
    source- my tint meter
