what is the fuel capacity after light goes on
Discussion in 'Technical Chat' started by vjherrera, Mar 6, 2013.
  1. Mar 6, 2013 at 3:04 AM
    vjherrera
    vjherrera [OP] Well-Known Member
    Vince
    Chicopee,MA
    Does any one know what is the fuel capacity after the low fuel warning light goes on.
  2. Mar 6, 2013 at 3:15 AM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2015 DCSB TRD Sport 6MT
    Mine is around 10 litres, but I have a first gen, not sure what you have.
  3. Mar 6, 2013 at 6:12 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I heard of there being some varience, but mine comes on after 17.4 gal are gone. I've seen reports of it coming on between 17 and 18 though. A search will get you many threads on this.
  4. Mar 6, 2013 at 9:10 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    The light comes on when you have burned 17 gallons and have 4 gallons remaining. (This is +/- 0.5 gallon true every time I pop into a station right when the light comes on).
    Some other data I have collected on the fuel gauge:
    At the 3/4 full line you have used 5 gallons (16 in the tank)
    At the 1/2 full line you have used 9 gallons (12 in the tank)
    At the 1/4 full line you have used 13 gallons (8 in the tank)
    At the Light activation you have used 17 gallons (4 in the tank)
    At the E line you have used 18 gallons (3 in the tank).
  5. Mar 6, 2013 at 3:25 PM
    vjherrera
    Vince
    Chicopee,MA
    thanks for the info guys, still use to my titan that had an 8 gallon reserve when light when off
