What is the going cost for a Rear bearing replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GibbsTacoma, Mar 1, 2025.
  1. Mar 7, 2025 at 6:22 AM
    safaridave
    safaridave Well-Known Member
    Richmond, Virginia
    06 Prerunner TRD OffRoad
    I think they will last a very long time- as long as you keep an eye on the wheel seals. if the seals go out and leak gear oil into the wheel bearing, the bearing is now contaminated and its grease is being displaced by the gear oil which will shorten its life dramatically. ask me how i know :)
    Peter603Taco likes this.
  2. Mar 7, 2025 at 7:41 AM
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    that is a common front wheel bearing noise. highway speed, and a hum when you turn one way or the other
  3. Mar 8, 2025 at 8:41 AM
    GibbsTacoma
    GibbsTacoma [OP] Well-Known Member
    Charlotte Metro Area
    2010 Tacoma TRD Sport DCSB 2wd
    Update: I ordered all of the seal components (OEM) from toyota online and both Koyo Rear bearing assemblies online. The parts ended up costing $360 total. My local mechanic will charge $650 for labor for both sides. So it's going to end up costing near $1,000. This is scheduled near the middle of this month.
  4. Mar 8, 2025 at 8:56 AM
    vtdog
    vtdog Well-Known Member
    NH
    I just had both rear bearings and rear brakes replaced on my 2011. The cost was about $ 1,800 for the whole thing. Expensive, yes, but not something I could either do myself due to both lack of correct tools and cold weather here in NH
  5. Mar 8, 2025 at 9:27 AM
    GibbsTacoma
    That's not bad as well. The good thing is that you probably won't have to replace again.
  6. Apr 10, 2025 at 8:21 PM
    GibbsTacoma
    I ended up buying the parts from toyota online parts and brought Koyo bearings. Labor cost me $650 so I ended up paying shy over $1k total. I felt I came out well for a solid truck.
    wmb67 and koditten like this.
