What is the largest size tire I can fit on my 09 Tacoma?
Discussion in 'Wheels & Tires' started by GKAJMUCF, Sep 19, 2011.
  1. Sep 19, 2011 at 7:48 PM
    GKAJMUCF
    GKAJMUCF [OP] Member
    I have a 2009 stock Tacoma reg cab and I am looking to upgrade my wheels and tires. I was looking at tires that were 255 70 16" but the guy at the truck store said they wouldn't fit. I don't have a lift but I have seen some other conversations on websites with people putting 265s on with no lift. I want to make sure I get the larger tire size i want before investing the money. I've been getting mixed views on this subject from different websites so i figured this would be the best place to ask! Will the larger tires hurt my stock suspension in the long run as well?
  2. Sep 19, 2011 at 7:52 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    what model do you have?
    Generally, 265/75r16
  3. Sep 19, 2011 at 7:53 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    :cookiemonster:
  4. Sep 19, 2011 at 7:56 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    What's the best way to lift my truck without having to do a diff drop? :stirthepot:
  5. Sep 19, 2011 at 7:56 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    THIS IS A STICKY IN THE TIRE SECTION!!!!!!
  6. Sep 19, 2011 at 7:57 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  7. Sep 19, 2011 at 7:57 PM
    NelsonTacoma
    Tucson, AZ
    :rofl: BTW I'm not in law enforcement. :D
  8. Sep 19, 2011 at 7:59 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    How much metal are you willing to cut?
  9. Sep 19, 2011 at 8:00 PM
    NelsonTacoma
    Tucson, AZ
    Good point. I'm just adding to the shenanigans. :p
  10. Sep 19, 2011 at 8:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Also OP, if you run slightly larger tires you will not hurt anything.
  11. Sep 20, 2011 at 7:45 AM
    GKAJMUCF
    Its the 2009 regular cab stock 4x2. I don't have a lift. So you can put 265s on this without lifting it and no clearance issues??? How much offset would be required???
  12. Sep 20, 2011 at 7:51 AM
    GKAJMUCF
    The wheels I was looking at also have a 38 offset. Does that reduce the size of the tire I put on?
  13. Sep 20, 2011 at 9:20 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Are you a 5-lug or 6-lug (prerunner)?
    What width are the wheels?
  14. Sep 20, 2011 at 4:27 PM
    GKAJMUCF
    Its a 5-lug (not a prerunner)
    I was going to have 265 75 16s put on but that what he said was to big and the biggest size i could go was 235-75-16. They aren't bad but not the size i wanted.
  15. Sep 20, 2011 at 4:44 PM
    KPT
    09 Prerunner
    Biggest is 235/75/15, not 16
  16. Sep 20, 2011 at 7:13 PM
    GKAJMUCF
    Thanks for your help. Im going with the 235-75-16s. I'm going to modify the width of my wheel well to accommodate.
