What is the minimum lift I will need?
Discussion in 'Wheels & Tires' started by apw100, Nov 7, 2009.
  1. Nov 7, 2009 at 4:39 PM
    apw100
    apw100 [OP] Well-Known Member
    Jacksonville, FL
    2015 4x4 TRD Off-Road
    Snug-Top cap, Kicker KS speaker upgrade
    I plan on getting some 285/70R16E Nitto Trail Grappler M/T tires and I was wondering what I would have to do to make these work.
    The specs of the Nitto's are 31.89"(diameter) 11.5"(section width), compared to the 30.6"(diameter)and 10.7"(width) of the BFG Rugged Terrains' that come with the TRD Off-Road.
    How much of a lift would I need? I would prefer to lift the truck as little as possible. I have a TRD Off-Road that has had the TSB done in the rear. I plan on getting a set of 5100's to add whatever lift I will need. Any other suggestions? I apologize in advance for my ignorance...
  2. Nov 7, 2009 at 4:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    2.5" should be fine, but you may have a little rubbing.
  3. Nov 8, 2009 at 6:28 PM
    apw100
    Jacksonville, FL
    Damn, I don't know if I want to go that high. I want a small lift and slightly bigger/more aggressive tires than stock, but I drive a lot and don't want to take a big hit on the mileage.
    I bought my Taco used and it came with 20" Enkei WT4's with 250/55R20 tires, good looking for a "street" truck buy not what I want.
    Any suggestions?
  4. Nov 8, 2009 at 6:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Get some 265/75/16's. You can clear them with a stock height, and they are 1 size larger than stock.
  5. Nov 8, 2009 at 7:45 PM
    apw100
    Jacksonville, FL
    What could I get on there with a 1" to 1.5" lift? Any difference?
  6. Nov 8, 2009 at 8:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not really....A 32" tall tire is about the max you can get before getting into rubbing issues.
  7. Nov 8, 2009 at 9:26 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I think those would probably fit with the 5100's at 1.75" and possibly either wheel spacers or aftermarket wheels if there is UCA contact issues with them.
