What is the most unreliable vehicle you have experienced?
Discussion in 'General Automotive' started by skiergd011013, May 19, 2015.
  1. May 22, 2015 at 10:00 AM
    #201
    [kiesster]
    [kiesster] Be water, my friend.
    Aaron
    Colorado
    2015 MGM V6 DCSB 4x4
    2003 Jeep Liberty Renegade-
    Rear power windows came off tracks
    Rear window latch broken
    Replaced radiator
    Rear axle leak
    Replaced front control arm/lower ball joint (recalled)
    Fuel system/gass tank assembly recalled
    Replaced both front hubs
    Air bag sensor recalled
    Blower motor stopped working on all but high
    Finally rod started knocking at 150k which prompted me to get my Tacoma
    However, the Jeep did manage to smash a full grown doe at 55mph with both axles only to have a fog light pop out.
  2. May 22, 2015 at 10:05 AM
    #202
    skiergd011013
    skiergd011013 [OP] Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    My moms old liberty's blower only worked on high. And my grams as well, lol.
  3. May 22, 2015 at 10:34 AM
    #203
    labmannn
    labmannn Well-Known Member
    Bill
    Mt. Juliet, TN
    2013 Tacoma TRD Sport Pkg 4WD
    window tinting, N-fab light bar, 4 Hella fog lights, N-fab step bars, 3" Pro Comp lift
  4. May 22, 2015 at 11:19 AM
    #204
    skiergd011013
    given the name of this thread, I dont think anybody on TW will be interested:D
  5. May 22, 2015 at 11:21 AM
    #205
    Kadowampus
    Kadowampus Well-Known Member
    Ventura County
    2011 SR5 4x4 extended cab
    front & rear 5100 Bilstein shocks, eibach/toytec coils, .5" lean spacer, 2" AAL, Derped wheels, Smittybuilt 8000, Technora line, Factor 55 Flatlink, ARB Bumper, Curt receiver, frontrunner load bars, eezi-awn 1600, Lightforce lights, pop-n-lock
    Pt cruiser
  6. May 23, 2015 at 9:25 PM
    #206
    BlueMile
    BlueMile Frozen north specialist
    Patrick
    North/Central Alberta
    2009 TRD Sport
    ATV trail dents, many, many lights, 4-6 beer cans.
    Mine had to be my old 1994 Taurus.
    • When I got it at 160k it had a blown head gasket (was a project, ergo very cheap), but when I sold it for scrap (205k) it was on the way out again.
    • A transmission that had little to no idea what was the appropriate action to take when the pedal was depressed (I always thought it masqueraded as a standard stuck in 1 gear, until you had your foot hard down, then it would kick down 2 and you're at the redline...)
    • The front seats were designed to make you feel like you were ready to give birth
    • To reach the rear bank you had to take half the vacuum hoses and the intake plenum off to even think about changing plugs
    • 2x water pumps in 45k, 2 serpentine belts, a pulley tensioner and an alternator (all within about 3 months of each other, all required half engine disassembly)
    • The heater worked when it wanted to, not before, not after
    • A trunk lid that didn't like to stay closed
    • Body panels that would dent if you glared at them hard enough
    • Paint that peeled at the sight of sunlight
    That car saw some good times at my expense though, it also taught me to stay away from transverse domestics, and in fact, any domestic that didn't have the classic '18 moving parts' application and a roomy engine bay.
  7. May 23, 2015 at 11:31 PM
    #207
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    1950 Dodge coronet, followed closely by a 1983 Mercury Capri.
  8. May 24, 2015 at 5:33 AM
    #208
    Samjo
    Samjo Member
    Covington, Georgia
    15 DCSB TRD 4x4
    Biggest POS I ever owned, was an Oldsmobile Ciera station wagon. First time I changed the oil...the nut inside the oil pan broke loose. Couldn't get it come come out at all, although it was loose and about half way out. I had to push up on it with my finger....and let the "still too damn hot" oil run down my arm and off my elbow to drain. I couldn't get it to screw back in with a ratchet. Grabbed my air impact, and bumped it quick, and it caught. I tightened it back up, and finished my oil change.............and traded that POS before it was due another oil change.
  9. May 24, 2015 at 5:53 AM
    #209
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Funny, My parents had a '95 wagon that was probably the most reliable thing I've ever seen. Rust finally got it in the end. They bought it new and it never had a non-routine issue. Even the OEM battery lasted almost 10 years!
    They had a couple of '99s which were not nearly as good, though. The Duratec engines they had were rock solid, but that's about it. Weird electrical issues, awful transmissions (that never actually failed but sure didn't shift well!), and a lot of fit and finish quality issues. I could never get over the stupid oil filter placement on them, either.
  10. May 24, 2015 at 6:16 AM
    #210
    Jarlaxle
    Jarlaxle Well-Known Member
    New England
    Not a Tacoma yet...
    My Magnum had one minor problem (rear defrost feeding back into the stereo) in the ~88,000 miles I owned it. Dealer fixed it at the next scheduled service...offered to do it right away, but it wasn't that big a deal.
    My Cherokee ranks as the most reliable vehicle I have ever owned...sold (and still running 2 years later) with 220,000 miles, still with the original water pump!
    My stepfather has put 200,000+ miles (each) on two different Concordes...now has and loves a 300.
  11. May 24, 2015 at 6:18 AM
    #211
    Jarlaxle
    New England
    Not a Tacoma yet...
    That's because most of them rotted in half before they could wear out. :p
  12. May 24, 2015 at 6:19 AM
    #212
    Jarlaxle
    New England
    Not a Tacoma yet...
    The 2000 Cherokee had no distributor! Methinks you got ripped off.
  13. May 24, 2015 at 6:27 AM
    #213
    Jarlaxle
    New England
    Not a Tacoma yet...
    My mother had two (1995 SOHC, 1998 DOHC), a good friend had one (1997 DOHC). None used oil...my friend's was scrapped (rust) with over 200,000 miles. And he did NOT baby that car...let's say that he knew where the DOHC Neon powerband was, and used it!
    I will say the Illinois-built cars are better than the Mexican-built cars.
  14. May 24, 2015 at 6:31 AM
    #214
    Jarlaxle
    New England
    Not a Tacoma yet...
    Muscle cars cannot be wrong wheel drive.
  15. May 24, 2015 at 6:32 AM
    #215
    Jarlaxle
    New England
    Not a Tacoma yet...
    Not 1972...1975.
  16. May 24, 2015 at 6:38 AM
    #216
    Jarlaxle
    New England
    Not a Tacoma yet...
    It was good enough that the SCCA changed Showroom Stock rules to make them uncompetitive!
  17. May 24, 2015 at 6:40 AM
    #217
    Jarlaxle
    New England
    Not a Tacoma yet...
    Some are...
  18. May 24, 2015 at 6:51 AM
    #218
    Jarlaxle
    New England
    Not a Tacoma yet...
    I worked for a livery company that regularly ran them 300,000+ miles. Of course...they maintained them, soccer moms often don't!
  19. May 24, 2015 at 6:51 AM
    #219
    Jarlaxle
    New England
    Not a Tacoma yet...
    Bad resistor...$15 and a 10 minute fix.
  20. May 24, 2015 at 6:54 AM
    #220
    Brent Waldman
    Brent Waldman Active Member
    Brent
    Grand Junction Colorado
    2005 Tacoma TRD Off Road
    2.5 in lift
    2012 Jeep Rubicon Unlimited. Replaced the left head twice and the transmission is crap. Have replaced it with a Toyota.
